Old 05-02-2021, 06:39 PM
Nightowl66 Nightowl66 is offline
Default 3206 Lift valve o rings
I have a 3206 leaking from the top of the lift valve. I have it torn apart and going to replace o rings. I had read somewhere that someone used the Harbor Freight standard and metric kits to rebuild theirs. I have the correct o rings for the lines, but for the spool the size is 16mm OD x 11mm ID x 2.5mm thick. The Harbor Freight closest size is 15.6 x 10.8 x 2.4. I am assuming that won't work? I was hoping it would since I already have both sets.
I did find these on Amazon: Nitrile Rubber O-Rings, 16mm OD 11mm ID 2.5mm Width, Metric Buna-N Sealing Gasket
Old 05-02-2021, 08:19 PM
Here are the McMaster-Carr #
https://www.mcmaster.com/
Spool valve O rings -- 9262k234
Hydro lines -- O-ring 9452k19
Back up ring 5288t117
Replace the spring while you are in there too. Cub Cadet part#732-3059
Check post #9
https://www.onlycubcadets.net/forum/...light=9262k234
And this one too.
https://www.onlycubcadets.net/forum/...light=732-3059
Good luck and let us know how it goes.
Old 05-02-2021, 09:32 PM
Check post #9
And this one too.
Thanks, Order placed. I ordered the backup rings also, mine didn't have them although the parts list showed them.
