Old 05-03-2021, 11:46 AM
mortten mortten is offline
When the lever is forward you should have only enough space between the button and the PTO so it doesn’t rub. That will give you maximum throw to disengage when you pull the lever back.
Doug
QA-36A
42" blade
Old 05-13-2021, 09:54 PM
jbrewer's Avatar
jbrewer jbrewer is offline
Well, I drove it around today. It ran well, it stopped fairly well and the steering is light years better than before. I'm going to put it the fenders on tomorrow and see how this works with the deck under it.
Fun stuff. The replacement engine seems to run fine now.
I'll have to take a picture. MAN are those LED headlights bright!
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
It's only original ONCE!
Old 05-15-2021, 04:30 PM
jbrewer's Avatar
Here it is,
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
Old 05-15-2021, 08:29 PM
Good to see you are finally getting some pleasure cutting the grass, like I did with mine.
Now about those headlights......
Old 05-15-2021, 08:50 PM
jbrewer's Avatar
It's got a twin brother! Nice cub Lew!
This was my first cub (I bought it after my 2nd disposable Big Box store mower). It's been 10 yrs now.
Headlights...Did I mention how bright those bad boys are?
Engine swap turned out to be :
Engine swap
Clean parts
Steering box rebuild
Clean parts
New wiring harness
Clean parts
New tie rod, drag link ends,
Clean parts
New points/condenser/timing
Swap PTO (gauges came today)
Fix brakes (and clean parts)
and...oh yes! Clean parts (and paint)
This old thing has about 5 coats of paint on it (no 2 alike) but it's nice to have it running again.
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
