Old 05-08-2021, 11:56 AM
Rainman4820 Rainman4820 is offline
Default 1541 Mower PTO Wont Engage
I hit a small tree root this morning but it was big enough to stop the mower. It wasn't an abrupt stop, but stopped it nonetheless. I let it cool down and it started right up, but when I try to engage the mower, I get nothing. Blades turn freely.
Ideas on where to start troubleshooting?
Thanks
Old 05-08-2021, 12:26 PM
broken belt?
Up to 534 and counting...
Old 05-08-2021, 06:53 PM
Default 1541 pto
Belts good, when I engage or press the momentary PTO Switch to up position, nothing happens. The light on the dash comes on as usual but no engagement, sounds or anything at all.
Thanks
Old 05-08-2021, 06:54 PM
Is the wire connector from the PTO to the Harness Connector intact ??
Old 05-11-2021, 02:48 PM
Default PTO Issue
I appreciate the thought but now I don't think its electrical.
I tried to start once again and it kicked over once, there was an abrupt thump and then died. I am going to check further and will get back with my findings.
Old 05-11-2021, 07:30 PM
Sounds like a seized PTO bearing. Remove it and see if the engine will start.
Old 05-11-2021, 10:25 PM
Billy-O's Avatar
Billy-O Billy-O is offline
Look under deck, again. You did say you hit a tree root. Yes, you did say blades turn freely....but which way did you turn it?
Plow blade
#2 Cart
QA36 snowthower
Old 05-12-2021, 07:47 AM
ironman's Avatar
ironman ironman is offline
I suggest the logical thing to do would be to remove the PTO drive belt and test run the engine?
You can also check the PTO operation while doing that.
Now you can check the deck spindles and blades for binding, broken, bent with no drag on it.
Old 05-12-2021, 08:38 AM
Just wondering what the "root" cause is?
Old 05-12-2021, 12:57 PM
Eventually we will get to the root of this problem.
