Old 05-14-2021, 09:23 PM
Ken41's Avatar
Ken41 Ken41 is offline
Default 3240
It looks like I will be buying the 3240 Cub Cadet that I ran into. He cleaned it up for me also and might get delivered Sunday hopefully!
Old 05-14-2021, 09:43 PM
ejl6658 ejl6658 is offline
The 3000 series are great machines and I think you will enjoy having bought it.
Old 05-15-2021, 07:31 AM
+1 on that.
Old 05-17-2021, 10:59 PM
Ken41's Avatar
I did get here on Sunday. Thought I would start puttering around with the 3240 today. So I did a compression test and came up with 160 psi in each cylinder and when it runs I do not hear valve train or lower end noise, the oil looked decent so I think I have a good engine that has 461 hours on it. I started making a list of things that I need and it is adding up fast. I need a PTO switch, vacuum solenoid and ignition switch for starts. They work but a broken in other ways. Any one have parts machines around to sell me some parts? I am checking out E-Bay but half the time they do not answer. Think I will order up the O-rings and seals soon also so I will be ready to pull out the differential to check it out. The wheel lock works and there are not any noises coming from there that I know of.
Old 05-18-2021, 10:02 PM
Ken41's Avatar
I am thinking about pulling the 22 HP Kohler from the tractor to clean and look it over. Does anyone know how much it weighs? Can I pick it up my self?
Old 05-19-2021, 01:16 AM
guyina4x4's Avatar
guyina4x4 guyina4x4 is offline
it weighs around 90-100lbs
I can and have lifted many of them out and back in again. I wouldn't want to carry it very far but just to move it from tractor to bench is doable.
at 460 hours it most likely needs a good cleaning and I'd be amazed if it doesn't need head gaskets and crank seals.
JD x475
Old 05-19-2021, 06:58 AM
CubDieselFan's Avatar
No, I would not recommend you picking it up my yourself. Get a helper, it much easier with 2 people. Your back will thank you when you get older.
Old 05-19-2021, 10:54 PM
Ken41's Avatar
I did a compression test on it a and it is at 160 PSI each cylinder. That is good right? How would I know if it needs head gaskets?
Old 05-19-2021, 11:00 PM
Ken41's Avatar
I already am older! I set up a come-along and a cart since I have a beam going across in my garage. Unfortunately I have no one to help me except advice from you guys on the forums.
Old 05-21-2021, 10:43 PM
Ken41's Avatar
I got the engine pulled tonight. I also have limited space and almost regretted buying this because of that. But now that I am into it I am managing and having fun.
