Old 05-30-2021, 06:53 AM
twoton twoton is offline
In your first picture in post 8 it looks like the nut on the throttle cable is bent and hitting the blower housing.
Old 05-30-2021, 09:09 AM
dale c. dale c. is offline
I agree with twoton the cable should be on the outside of the arm . and your motor mounts must be totally gone also the cables are supposed to come through the oval hole in the fire wall . but the engine is way too low
Old 05-30-2021, 09:24 AM
Here's some pic's of my 1450 wrebuilt carb and properly adjusted governor
Old 05-30-2021, 01:24 PM
IHCC1250 IHCC1250 is offline
Thank you!
Old 05-30-2021, 01:26 PM
That’s odd. The engine seems very well secure in place. Doesn’t rock back or anything. And no driveshaft wobble either. I may recall someone doing a modification a while back to it...
Old 05-30-2021, 01:30 PM
Is that at idle, or part speed?
Old 05-30-2021, 03:09 PM
I believe it was at idle.
If you have not already messed with the carb to gov lever, don't
Chances are it's OK
Mine in the picks is at about 2.9" C/L to C/L
Somewhere in the manuals I have is a chart that spec' that length for different engine applications but I'll be darned if I can find it.
Old 05-30-2021, 03:58 PM
Chances are it's OK
Yeah I’ve noticed something else too. A while back I got a photo of where my old throttle cable was on the clamp. I compare that to now and something has changed. I think I may need to move the position of the throttle cable on this clamp thing. It has moved.
File Type: jpg AFB2530B-45ED-4BA4-8CFD-78C18D42B24C.jpg (19.6 KB, 40 views)
File Type: jpg 963B5F14-32DE-4B66-A6BA-581ED4105745.jpg (20.9 KB, 39 views)
Old 05-30-2021, 03:59 PM
Chances are it's OK
I have messed with it. What is a good setting to screw it to?
Tags
1250, carb, k301, throttle
