Old 06-01-2021, 03:04 PM
Rainman4820 Rainman4820 is offline
Default 1641 Hydro Drive Adjustment
Can someone provide the service manual or instructions to adjust the hydrostatic transmission neutral position on a 1641. Mine creeps backwards slowly when in neutral. Thank you
Old 06-03-2021, 10:05 AM
Hello is this thing turned on?
Old 06-03-2021, 10:58 AM
With the limited information you supplied, there were 3 runs of the 1641 depending on serial number range.
The 1641 had a Hydro Gear transmission different from the Sundstrand that was normally used.
I looked through my Library and could not find anything as far as a Service Manual for the Tractor Chassis, nor anything on Hydro Gear.
The best I can come up with is a Owner's Manual.
Old 06-03-2021, 11:10 AM
UPDATE:
In looking at a generic parts diagram, I would "assume" that you could adjust the linkage on the "connecting rod" [#13] that attaches to the "cam plate" [#29].
Old 06-03-2021, 02:38 PM
You adjust the hydro gear linkage the same way as the Sundstrand. you raise or lower #26 to get neutral
Old 06-03-2021, 03:17 PM
Thank you both for your responses and I appreciate the diagram. I will report back with pictures just in case others have similar issues.
Old 06-03-2021, 07:07 PM
ironman's Avatar
ironman ironman is offline
Here are the instructions for a Sunstrand from Service Bulletin CC-188 March 5, 1990.
Old 06-05-2021, 02:44 PM
UPDATE:
Removing the pan just below the dash provided access and adjusting the linkage for the connecting rod #13 was the correct fix for my 1641. My model number is 144-653-100
Loosening the 2 locking nuts and threading the rod forward (essentially moving the cam backward) and then securing the locks nuts worked to keep her from moving while in neutral.
All good, many thanks for the responses and diagram.
