Old 06-13-2021, 08:36 PM
Jim in SC's Avatar
Jim in SC Jim in SC is offline
Default Clutch assembly removal question
I'm pretty much rebuilding my recently purchased CC 100. I've pulled the engine and set it aside and want to remove and rebuild the clutch assembly, which currently has a broken teaser spring and the clutch disc's drive holes are "wallered" out. I'm going to replace both of those items and also the main load spring.
I need some expert advice on the removal of the clutch assembly. I searched around on the internet and found one guy who warned that when the pins are driven out of the coupler at the transmission, that the input shaft must be braced to prevent damage. I'm not sure I understand what this means. Any idea or advice on the best way to remove the input (drive) shaft from this coupler? How do I "brace the drive shaft?
1951 Farmall H; 1957 Willys CJ5; 1959 Farmall Cub; 1961 Cub Cadet Original; 1963 & 1964 Cub Cadet 100's; 1971 Cub Cadet 106
Old 06-14-2021, 09:53 AM
ironman's Avatar
ironman ironman is offline
"Bracing" would be any thing that you can come up with that you can wedge in there to support the input shaft of the transmission while you are driving out the pin so that you don't damage the input shaft bearing or seal.
Old 06-14-2021, 12:40 PM
Anything you can stick under/between the driveshaft and table or between the driveshaft and the frame or wherever to support it while driving out the pins to avoid damage to the input shaft bushing and seal
Standing that little guy up on his butt will make things a bunch easier.
Old 06-14-2021, 01:46 PM
Jim in SC's Avatar
Thanks to you and to Ironman - I think I understand it a little better now - made sense when I saw the gear teeth...
By "standing it up," I take it that the bushing doesn't need to be moving during and after the removal of the drive shaft. It's not on it's butt just now, but I do have the front of the tractor elevated, so that should help.
Thanks again. I'll post again when I get 'er done...
Old 06-14-2021, 02:21 PM
Cubcadet_107's Avatar
I stood up one of my John Deere's over the winter. Cub's definitely got more weight to it but shouldn't be too difficult considering you've pulled the engine already
'70 107 with k301 engine swap
'71 106 with 38" deck
'63 70 "pinkie"
1863 with 54" deck
105 x2 (parts)
Old 06-14-2021, 02:51 PM
Anyway you look at it, it's going to be a PITA to get them pins out tregardless how you go about it.
Best to have a 2nd pair of hands to assist and hold things steady.
Old 06-14-2021, 05:27 PM
Jim in SC's Avatar
I'll give it a try the way it is without standing it up - I just changed the tranny fluid and don't want to mess with that for awhile. If it becomes a real chore, I guess I could drain it and refill it later...
Soaking those pins in PB right now. Do both pins have to come out?
Old 06-14-2021, 06:15 PM
Only one (the easiest one to access) unless you have a ton of slop in the coupler, in which case it should be replaced and even possibly the driveshaft as well if there is a lot of wear on the ends or if the holes are wallered out
Old 06-14-2021, 07:07 PM
I would split the tractor and remove the clutch that way. Being the engine is out, you can remove all the clutch parts on one end and then remove the shaft and clutch arm after you split it.BTDT
Old 06-15-2021, 07:44 AM
ironman's Avatar
It's a gear drive.
You shouldn't have to drain any oil.
When stood, up the oil level will not reach the opening on the shifter, the only place it can run out.
Just don't turn it completely upside down.
