Old 07-01-2021, 01:43 PM
ICOM 756 ICOM 756 is offline
Originally Posted by ironman View Post
It has always been my understanding that starter/generators, as opposed to generators, do not have to be manually polarized.
When you did what you thought was repolarizing by touching the S/G "A" terminal to battery plus, it is done automatically the first time you hit the starter solenoid as you can see in the wiring diagram.
So, your problem may be solved, but not by "re-polarizing".
By the way, on a 4-lug regulator, the post on the bottom is the equivelent of the "GEN" lug on 3-lug regulators. The "L" lug (or Load) on 4-lug regulators is for providing greater current to high drain loads such as lights or other accessories.
In addition, if you are seeing 16-17 volts and and consider that "isn't running away on the voltage now", how much would you consider to be "running away"?
not sure as the polarizing but it seems to be working. it was my understanding they needed that.. so iam lost there..
run away voltage was goin to 17 plus. hittin 18... within 10 mins of run. it wasnt comming off 17 to 18. also amp gauge peged rite... now its floating all over place. 13 to 16.5, so iam guessing the VR is working .
after touching A to bat. it doesnt do that no more. i just mowed for hour and she ran around the 1st line above 0 . wasnt jumping all over like my other 127 does. seems stable now.
so i have no clue. you say no need to pole it. yet ive read and seen vids to do it. so ill leave that one to the experts. iam far from one thats for sure.
thank you all for the help for sure.. cold bev or hot your choices. say my name they take care of ya lol
edit ps... if iam wrong or doing wrong. pelase tell me so i learn what iam doing here. rebuild a motor is much easier then wiring for me lol ... tho these are pretty simple compared to cars and trucks. hahhaha will new stuff. give me a ole SQ body anyday lol
Old 07-02-2021, 05:55 AM
Default oooo
wow one thing or another... now i have to let off the key to start it..
in start postion crank a few times then let key go and it fires.
i give up lol
Old 07-02-2021, 07:19 AM
That problem sounds like you are not maintaining the power to the ign coil during the cranking phase.
Put your meter on the +side of the coil and see if you are getting near 12 volts
when your cranking the engine over with the key switch.
Also:
A weak bat-tree might be producing enough power for the starter, but not enough for the coil.
your wiring circuit is a simple one, not complex like some later models, so you should be able to find your problems easily.
Old 07-02-2021, 08:00 AM
mickb72 mickb72 is offline
i give up lol
Another bad key switch. Did i ever say i hate them? Yes i have. !6-17 is to high for the S/G. Should be 13-14.5. There is a process to adjust them. Ol George could be right though. My money's on the switch. Mike PS Clean both ends of your ground cable.
Old 07-02-2021, 08:27 AM
ironman's Avatar
ironman ironman is online now
Or it's the WRONG key switch.
As we all know (or should know), not all key switches are created equal.
Old 07-02-2021, 09:07 PM
ol'geo.........
ty for info i didnt even think of that.. bat tree is brandy new. i dont remember i think i tired another ing switch and did same. it was another 127.. but will check the coil..
mickb72....
thats the highs.. meter on bat tree. its floating all over the place.. 2 volts to 13 to 12 to 16to 9 . so iam guessing its working ok .. tho i could be way off and wrong..
ironman....
i dont think its wrong one.. its the 3 wire ... as i said to geo up above.. i dont remember if i tired another one i have and if i did .. if it did the samething..
but with what GEO said test coil input it will get me in right area.. it should tell me if its cuttin voltage off to coil..
heck might be just old switch.. dirty and or copper wore off inside..
ill know more when i test coil.
Old 07-03-2021, 02:12 PM
Jim in SC's Avatar
Jim in SC Jim in SC is offline
Amazing...
1951 Farmall H; 1957 Willys CJ5; 1959 Farmall Cub; 1961 Cub Cadet Original; 1963 & 1964 Cub Cadet 100's; 1971 Cub Cadet 106
Old 07-04-2021, 07:59 AM
jbrewer's Avatar
jbrewer jbrewer is offline
Something is still way wrong. Voltage should not vary much at all in normal use...should go from just about 12V to around 14v. Amp's should not be pegged or "floating all over."
Grounds clean? I know this was mentioned before, but is it?
Coil shouldn't cause any of this.
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
It's only original ONCE!
Old 07-04-2021, 05:37 PM
Default its the switch
its the switch..
seems the detent to stop you from turning past the contects is lil ware down..
i had one in another tractor.. took it apart. cleaned it up and thats what it did also ..
note to self.. if u go to far with the alloy edge thats bent over the switch plate.. hahhaha it will rip lol ...
its ok tho wasnt working anyways lol ... the blades for the plug were a bit ruster then i would like anyways lol
ty to ol geo..
Old 07-04-2021, 05:42 PM
its stayin steady on the amp gauge.. sits around left of the 1st line to the rite.
it could be my meter tho.. i have 2 of them. but there the cheapos. i have to find a good meter to grab..
becuse as i read your post. iam thinking.. if its hooked to battery.. it shouldnt go below 12 volts or what ever the battery is at.. and the meter was goin from 2 volts peaking to 16ish..
been running it nothing blew up yet lol ..
will update once i get a better meter or a new one ..
