Old 12-14-2010, 10:24 AM
nikster's Avatar
nikster nikster is offline
Default Snow blade dilema? #109 vs. #122
Bear with me if possible? I searched & searched,
I would need a very simple solution that lets say a 10y.o., would be able to understand.
I have a snow blade for my # 109, being a wide frame. Thats easy?
Now can I hook up that blade in some manner to my # 122 being a narrow frame? Thats the question?
I remember somewhere's that someone wrote that it can be done without to much hassle?
Can anyone direct me into the right direction?
Service manual?
Some type of extended bolts to adapt to a wide frame ?
Or?
What does one do?
Or not worth the bother?
Thanks in advance,
Nik
Geeesh, alot of question marks in this post.
Old 12-14-2010, 11:16 AM
You need a NF subframe.
Old 12-14-2010, 09:27 PM
nikster's Avatar
Let's see if I get this?
Drop my cutting deck & the plow should fit?
Nik,
Old 12-14-2010, 10:18 PM
TEET's Avatar
TEET TEET is offline
You need to remove the wide frame sub-frame from the plow, and find a narrow frame sub-frame to re-attach to the plow so you can use it on your 122..is that simple enough?
There is no way to make your current subframe fit your 122 without cutting, grinding, and cobbing it together. It would be easier to find a narrow frame one.
so like Matt said...find a NF sub-frame, and you will be good to go :biggrin2.gif:
Jeff (teet)
CCC 1211
71
127
102
122
1962 Original
Old 12-16-2010, 05:23 PM
loghouse loghouse is offline
Default NF subframe
If you check right now in the "For sale" section ther is a guy in Ohio with a narrow subframe for sale.
