I had my plow on the rear of my Cub Original and as I drive with it attached, every little bump I go over, the plow bounces and the plow gets bounced down. The next notch with the button on the implement handle fully pushed out. I have no clue what this could be. Any ideas?
There are several ideas that comes to mind... Weak, broken lift spring. Or lift push pin button not seated (threaded) all the way into the hook rod. Or hook on rod bent out of place, broken or worn.
Two 125's and a 124 all with 42" decks Plow blade #2 Cart QA36 snowthower |
