Old 09-18-2021, 12:50 AM
1574trap 1574trap is offline
Default Cub Cadet 2182 PTO clutch
I need to replace my 2182 PTO clutch. So far, I have tried eBay and Exteme for a replacement. eBay was a bust and got ripped off. Extreme sent what they said was a correct PTO clutch for a 2182. It was wrong and don't think they know or understand what it takes to make a PTO clutch correct for a 2182. Is anyone out there that has actually bought a replacement PTO clutch for a Cub Cadet 2182 would like to hear from you, with the company used, and your experience with the clutch.
Old 09-18-2021, 06:31 AM
There are three (3) generations of the 2182, depending on serial number range.
Generations 1 & 2 used PTO Assembly 717-3467
Generation 3 used PTO Assembly 917-3389
I don't know, neither does eBay or Extreme, which generation you have.
IF..........you go to the tractor Model/Serial tag, on the left hand side of the frame, and tell us what you serial number is, we will tell you the correct PTO for your tractor.
Old 09-18-2021, 09:01 AM
You folks should really spend a little time learning how to navigate the CCC parts lookup site.
If a 77 year old geezer like me can do it, anyone should be able to do it
https://www.cubcadet.com/en_US/conte...rtstream.html#
Old 09-18-2021, 09:24 AM
CubDieselFan's Avatar
Xtreme list 2 different clutches available. Based on serial number. One is 4” for the older model and a 6” for the newer model. Did you call or email them and ask for help?
Old 09-18-2021, 09:32 AM
If yours isn't burned up just put new bearings in it for less than $20.
Here is how the pto looked on my 1992 2182 when I got it.
Old 09-18-2021, 10:27 AM
I installed new bearings in my GTX2154LE PTO earlier this spring as well.
Old 09-18-2021, 10:07 PM
Default finsruskw
guess i will have to pay retail on the pto clutch for a 2182. almost no one and the PTO sellers included -- understand the 2182 clutch is different than the usual lawn mower clutches.
Old 09-18-2021, 10:19 PM
What is the part number you need?
Up to 534 and counting...
Old 09-18-2021, 10:33 PM
Post some pictures of your original and the ones you purchased if you still have them. Also, post a picture of your serial number tag.
Old 09-18-2021, 10:35 PM
They are not that much different unless you have one somebody has modified. How long have you owed it?
