Old 09-23-2021, 12:31 PM
Workingstiff Workingstiff is offline
Default 1200 front axle
On my new purchase, I have lots of slop front to back at my axle pivot point. The axle is moving on the pivot. Anyone have any input?
'76 1200 Dad bought
'75 1200 "Twinsie" per my daughter
Old 09-23-2021, 01:19 PM
Remove the axle and put the "squeeze" on the C channel and/or shim it back tight.
Was the pivot pin. .75", in good shape from end to end?
Make sure it is getting lube through the grease fitting.
Old 09-23-2021, 01:29 PM
That's what I was hoping to hear. I have not disassembled it yet. I did a search and came across a bunch of threads having trouble with stuck pins. I haven't been in there yet, does the pin rotate or is it fixed? Can it be turned over?
'76 1200 Dad bought
Old 09-23-2021, 01:53 PM
mortten mortten is offline
Pin is held stationary with a spiral pin. The pin being stuck in the axle is bad. Then the spiral pin is broken and the pivot is moving in the frame bushings causing wear. DAMHIK. If the axle is moving front to back on the pivot then that’s not the problem.
Doug
QA-36A
42" blade
Old 09-23-2021, 02:09 PM
So then you agree its probably the "C" channel widened through use and abuse? Should I be able to flip the pin 180°s?
'76 1200 Dad bought
Old 09-23-2021, 04:02 PM
Yes but that won't help the back and forth movement, especially if the bushings are worn, loose or, in the case of the rear one, even missing!!
Have seen that before as well.
Old 09-23-2021, 08:28 PM
Yes probably C channel. Don’t know if there would be any benefit to flipping the pivot but can be done.
Doug
QA-36A
42" blade
Old 09-23-2021, 09:32 PM
My thinking with flipping the pivot, would be the wear should be on the bottom/load bearing side.
'76 1200 Dad bought
Old 09-26-2021, 09:33 AM
dale c. dale c. is offline
you can use a 1/2" bolt & nut to squeeze the c-channel back together. do this while you have the engine out
Old 09-26-2021, 11:00 AM
Better if using a 3/4" bolt.
Will take a LOT of torque to bring it back into spec.
