Old 10-12-2021, 06:15 PM
That_cub_dude1847 That_cub_dude1847 is offline
Default Original input shaft seal
You can view the service manual for the original on how to remove. 2 bolts on left side, one bolt on right side, remove clutch actuator shaft, and 2 bolts at flex coupler, drop out drive shaft and clutch as a unit. Drive out spiral pin at input shaft and remove coupler. Put a couple screws in the seal and pull out with vice grips. I would make sure you don't have a lot of play in the input and inspect input shaft for scoring. Both of which will make it leak. Here is a pic of clutch you will be removing. You can take out entire rear with 4 big 3/4 head bolts and disconnect brake linkage too but I think this can be done under tractor with rear in place just as easy.
Attachment 63699
Should I put any sealant around the seal?
Old 10-12-2021, 06:52 PM
No. 10 characters
