This is my home made bead seater.buying one would have cost me $300. Its just an old L.P. tank:biggrin2.gif:
Jeff that is a good idea, I needed one yesterday, My Cub Cadet had a flat and I didn't see it untill I started to back out and Guess what
![]() yep I had to put a strap around the tire to get it to seat before it would Keep Air. I need to look at my tires before I take off ![]()
Retired U.S. Navy and Happy to Live in the U.S.A ![]() |
Well the Wife let me buy another piece of property to store all my toys on, and she said I had to fence it in, it joins our other property so I only had to fence three sides, so it was going to take 36 post, and in Arkansas putting in post holes is a Big Hard Job, and i didn't want to put in Nine inch holes the size of my Digger and could not find a small digger to buy, So I went to work in the shop and Built a 2 1/2 inch Bit, and Boy did it work, We put in All 36 Post with concret in TWO DAYS
What did you make the screw part from? That is a good looking bit!
I used to have a roll around tool rack like the one that started this thread, unfortunately when I am away from home a lot I need to secure my stuff and ended up with a rollcab instead. The rack saved tons of time when I was wrenching for a living.
Quietlines and narrow frames, mostly projects but I mow with a 1200 and have a 122 set up for pulls. Wandering the country bringing towers to wind farms everywhere, and bringing yellow stuff home to Texas. Also into flatfender jeeps. |
I used 2 1/2 inch washers that had a 1 inch hole in them and then cut one side and open or spread them open 1 inch and welded them on a 1 inch piece of round stock, the U joint is from a 1200 Goldwing motorcycle,
thats not a dog wrench!!! thats an alarm system!!!
Scott Larson Climax,MN Its not cold. its gods way of keeping the rif-raf out. |
I went over to a friends to help him with a little mowing, he did not tell me he had a little water problem in the back yard, I got her out and after a hour with a water hose she is clean again, My Wife told me Not to Help Him
Funny how threads sort of evolve. I was looking forward to seeing everybody's workbenches, toolboxes, and workshops. Oh well. This is fun, too.:biggrin2.gif:
I have two bead-seaters. One for easy jobs, looks just like a cargo strap. In fact it is a cargo strap. Just strap it around the tire, then tighten it up real tight. Then apply air to the valve, and voila! Bead seated. Works for lawn tractor tires, dolly tires, and other small softer tires. For bigger tires, harder tires, I have this little can of starter fluid.....Careful now, just a quick spray....stand back....toss a match at it....voila! Tire bead seated! That way is a lot more exciting.
Tony Stafford, VA 1650, 682... |
![]() Quote:
Get enough ether in a tire and it will bounce 3 - 4 feet off the floor! Not so sure that this is a method that I want to pass down to the younger generation.
o0o0o0o0o... I love to play with fire anyway. That looks like fun, I had completely forgotten about using that method. Now where did I put my matches??? :biggrin2.gif:
