Old 10-19-2021, 06:58 PM
EternalArianne EternalArianne is offline
Originally Posted by Sc120sc View Post
Many pressure washers used that engine with a manual choke. Find one and swap the carb and linkage.
Been there done that. Primer problem solved.
I do have a pressure washer with primer bulb that runs but the pump is ded. Maybe this weekend I'll see if the carb will fit this engine and swap them out!
Old 10-23-2021, 02:50 PM
Well the carb from the pressure washer didn't fit, and the original carb still won't work even after cleaning. I guess it's a new carb altogether then, and this time the correct one lol
Old 10-23-2021, 07:06 PM
Billy-O's Avatar
Billy-O Billy-O is offline
I believe the new carb that you originally had on the machine when you started this post has a CHOKE. Use it when starting cold!
Plow blade
#2 Cart
QA36 snowthower
Old 10-23-2021, 07:24 PM
I can't access the choke lever on the new carb once it's all put together. I guess I could rig up some kind of extension for the choke but I'd rather just spend $10 on another carb that is correct and use the primer. I'll just keep this other carb (the one with the choke) in case I get another piece of equipment that needs it...
Old 10-24-2021, 05:31 PM
Ok I took the old carb apart and clean the sh!t outta it. Every tube/jet is clear, took the float and needle from the other carb (the one with the choke) and put it in there.
This thing should work, but it's not priming no matter how many presses of the bulb. I suspect there is an issue with the air cleaner backplate/gasket, as I feel no air coming out of the air channel when I press the bulb. I saw the video Cannon51 posted and the guy mentions doubling up on the gaskets to make the air channel seal better, I will see if I can find another gasket that fits...
Old 10-25-2021, 01:10 PM
Cannon51's Avatar
Cannon51 Cannon51 is offline
I had to clean a carb that used the primer bulb over the weekend, the gasket stayed on the carb when I took it apart. if the gasket stays on the carb I always remove it and put a new gasket on the filter housing. Because of the way the gasket goes on some tits and in a grove on the housing I have never had any luck getting them to work if I put it together with the gasket on the carb. Since the primary seal to get the choke to work is between the gasket and the housing I usually put a VERY THIN coat of Permatex 2 on half of the gasket where my finger is. Don't get it in the little hole. Be sure the gasket is on the tits and down in the grove. When you put the housing on don't crank it down to hard, I use a socket and screwdriver handle. I'm not a very mechanic so take this advise for what it's worth.
Cannon
Old 10-25-2021, 01:13 PM
Cannon51's Avatar
the other picture.
Old 10-25-2021, 03:44 PM
Yeah mine has that same air channel from the primer bulb to the hole on the carb. But it's not sealing since the primer is not working. I'm gonna try doubling up the gasket to see if seals enough to create the vacuum needed for priming, just gotta find some of those gaskets
Old 10-26-2021, 11:37 AM
Check your primer bulb for cracks and you might try replacing the rubber fitting on the primer bulb. It may not be creating a proper suction to pull fuel in. You can also try, "Mechanic In A Bottle". I'm not 100% sold on it, but I did purchase a Cub Cadet 268 snow blower from a guy who used it and it starts on the first pull every time.
Old 11-13-2021, 03:46 PM
Update: doubling up the gaskets didn't help. I ended up getting another new carb (the correct one this time) and now it primes and fires up in 1-2 pulls every time. I guess the old carb still had something gummed up even though I cleaned every tube and jet I could find. Now if I can just find some new 16" wheels for this thing that aren't $40/wheel, it'll be good as new!
