Old 12-29-2021, 02:23 PM
Farmall450's Avatar
Originally Posted by 05snopro440 View Post
Should have? They were available, sure, but you can mount a QA42A to a 2182 as well. As I said in the comment you responded to, mine is a QA42A, NOT the 2-stage 451/551.
Needs to have, if you wish it to work correctly.
The 2182 has a smaller diameter PTO pulley which will not spin your snow thrower fast enough to work properly.
I'm not saying you can't cobble it together, but it wasn't meant to be.
Old 12-29-2021, 03:09 PM
Red Dave Red Dave is offline
Originally Posted by Wntsom4 View Post
For years all my dad had on ours was a length of chain and two small clevis on each end.
I purchased a lift rod this year want to try it out. Think it was 28” for my 1250
For quite a few years I had a lift rod for my snowplow that was about 6" too short. I used a piece of light chain to extend it. Worked OK but it allowed the plow to float.
Last year I decided to do away with the chain and added a length of threaded rod to my short rod, along with a pair of couplings and lock nuts. Now I finally have a one piece rod. Works OK and now I can do a little light grading on dirt with the plow too.
Old 12-29-2021, 08:50 PM
05snopro440 05snopro440 is offline
I'm so sick of wrong advice that wasn't asked for on this site. I didn't ask for your advice, and you're incorrect about the use of a QA42A with my 2182. But thanks for the unnecessary aggravation.
"Unsolicited advice is usually more about the needs of the giver than the receiver."
1992 2182 with 48" deck, Kwik-Way loader, and QA42A Snow Thrower
2008 RZT 54
Old 12-30-2021, 07:58 AM
Farmall450's Avatar
There's nothing incorrect about a 451 or 551 blower being the only factory options for a 2182, as originally stated.
https://www.cubcadet.com/en_US/servi...parts#diagrams
Old 12-30-2021, 04:00 PM
JUST STOP.
2008 RZT 54
Old 12-30-2021, 09:27 PM
Farmall450's Avatar
JUST STOP.
Do you run a 44C deck on your 2182 as well?
The reason I comment is so in 3 years when a random guy googles this, he doesn't go buy the wrong blower and get disappointed from your...advice. I can make dang near anything fit on whatever tractor, but it doesn't mean I should
Old 12-31-2021, 11:05 AM
You don't actually know anything about the setup, so just stop. Please.
2008 RZT 54
