Old 01-07-2022, 03:21 AM
1811woody's Avatar
Default QA snow thrower
Tis the season. I have a cylops 1863 the only blower I have available now is my QA blower, will it mount up and work properly?
Old 01-07-2022, 05:30 AM
The QA36/42B Snowthrower should mount right up.
Old 01-07-2022, 10:43 AM
Farmall450's Avatar
It'll fit, but it probably won't be geared quite right (assuming your cyclops has the newer, smaller diameter PTO).
Probably not a huge concern, but performance will decrease.
Old 01-07-2022, 10:57 AM
The QAxxA/B were NOT designed for the Cyclops Series Tractors.
Old 01-07-2022, 03:31 PM
1811woody's Avatar
Do you know the diameter of the smaller pto pully? I would like to measure mine.
Old 01-07-2022, 03:38 PM
1811woody's Avatar
Yes I agree it is not designed for the cyclops, for now until I get my other blower I hope I can manage to get it going anyway I love a challenge. After all I one had it nstalled on my mtd husky.
Old 01-07-2022, 04:10 PM
05snopro440 05snopro440 is offline
Yes, you can use it on a cyclops.
1992 2182 with 48" deck, Kwik-Way loader, and QA42A Snow Thrower
2008 RZT 54
Old 01-07-2022, 05:00 PM
aagitch's Avatar
aagitch aagitch is offline
I was thinking that the later cyclops had a bigger diameter pto pulley
Adrian
2072 (789513)
Old 01-08-2022, 06:43 AM
1863's have the 6" PTO. My guess is that you will need to put a larger pulley on the blower or you will over speed it.
Old 01-08-2022, 04:31 PM
1811woody's Avatar
Thanks Sam Il'l look into that thought, I have to add though on my 1811 it seemed to be slow so maybe a little more speed is what it needs? Lol I wonder what rpm its rated for?
