Old 02-20-2022, 03:38 PM
K241S K241S is offline
Default Cub 149 with tiller
I recently purchased this 149 with a tiller. It has one extension on it. I have the hood, and various other panels and a coffee can of screws and bolts.
The guy I bought it from owned it 30+ years. Told me he got it at a farm auction his neighbor was having for $25 back then. He took it apart 10 years ago to do the head gasket and never got around to it.
https://youtube.com/shorts/fuU04zbURfM?
feature=share
I got it running for a bit and it does need a head gasket. From what I can tell, the tiller looks like it has never been off this 149. I looked up the serial number and this one was built in Dec. 1974.
It looks rough. I think it's worth fixing and getting running again. I was going to take the tiller off and put it on my other 149 or 782 (that requires changing the pulley).
I think for the price I paid, getting it up and running again and using it in my garden will be cool.
My other 149 has been plowing the driveway this winter.
Old 02-20-2022, 10:33 PM
Farmall450's Avatar
Nice looking 149s. I've only ran a tiller on a 1282 and it pulled hard. Hydro lift on the 149 should be a big plus!
Old 02-21-2022, 07:52 AM
The hydro lift will be nice for lifting the tiller. I know it's heavy I had to winch it up on my trailer from the barn it was sitting in.
Old 02-21-2022, 09:35 AM
Farmall450's Avatar
I've also never seen one with 1 of 2 extensions, but I guess that works?
Old 02-21-2022, 10:35 AM
Just a bit narrower is all.
You will likely need some weight on the front.
I made a custom front weight box for my 1650 and incorporated the mule drive into the structure.
If nothing else, it's a great place to put the larger stones you are likely to dredge up from time to time
Old 02-21-2022, 06:57 PM
Gary C Gary C is offline
That is a really cool idea! Great fab job!!
Old 02-21-2022, 07:28 PM
It gets a good workout every spring around here as I do a few gardens locally and some are pretty good size.
