Old 04-05-2022, 11:48 PM
joseph4594 joseph4594 is offline
Default 2082 question
I just bought a 2082 that sat for a few years , it runs good but the lever to lift the mower deck won't move , I found in the operating manual that the engine has to be running to move the lever, but the lever still won't move . anyone know if there is another way or is the spool valve stuck for some reason .
thanks for the help
Old 04-06-2022, 06:52 AM
NOT so. The Spool Valve may have a little rust on the input shaft. Use some penetrating fluid (ie: PB BLaster, Kroil, etc) on that shaft to loosen it up.
Same situation happened on my 1450, from sitting over the winter one time.
Old 04-06-2022, 01:34 PM
Farmall450's Avatar
They certainly move while the tractor is off.
Old 04-06-2022, 06:30 PM
ironman's Avatar
ironman ironman is online now
From the manual....
I think the key word here is "operate"
Old 04-06-2022, 08:30 PM
I took it as "stuck".
Old 04-07-2022, 12:22 AM
Brianator's Avatar
Brianator Brianator is offline
I as well. The spool input pin/shaft on my 149 was stuck pretty good but after a good soaking it freed up and I don't even have an engine in the tractor (yet)! Lol
1973 Cub Cadet 149 basketcase (Work In Progress)
~My Real Hobby Is Collecting Projects!~
Old 04-07-2022, 06:58 AM
ironman's Avatar
What I meant was....
The manual says "The engine must be running in order to operate the hydraulic lift".
Joseph said "I found in the operating manual that the engine has to be running to move the lever".
I think he is misinterpreting "operating the hydraulic lift" as "moving the lever".
Yes, I agree, it should move running or not and is probably stuck.
Old 04-07-2022, 01:56 PM
Farmall450's Avatar
Exactly. There's no interlock.
