Old 04-25-2022, 07:08 PM
Default The newest find
This was a Craigslist find, 20 min from home.
It came from the original owner.
Original with a dozer blade and 38" timed deck. Looks to be garage kept all its life.
Runs and drives, new chana carb and battery.
Has an oil leak on one rear axle, couple drops, fluid level is ok. No weather checking on all the tires.
I took the dozer blade off and put the deck on, chana carb is giving me a hard time when a load is put on it.
I am gonna put on a correct one and see if that makes a difference, it prolly will...
Got it for a Lew price.heheh
Old 04-25-2022, 07:46 PM
twoton twoton is offline
Nice! Original owner too.
Someone gave me one of those last year, in a basket.
Old 04-25-2022, 08:04 PM
Billy-O's Avatar
Billy-O Billy-O is offline
Nice find! I guess the serial number isn't worth bragging about?
Plow blade
#2 Cart
QA36 snowthower
Old 04-25-2022, 08:34 PM
23566, not a 3 digit.
Old 04-27-2022, 04:23 PM
RustyShackleford's Avatar
RustyShackleford RustyShackleford is offline
Those China carbs sure aren’t great. Don’t really see the appeal either, when you could spend just a shade more on a used Carter and a Kohler rebuild kit.
Of course you probably have a whole wall of new-in-box OEM carbs waiting in the wings anyhow
Old 04-29-2022, 06:34 PM
So I put the old carb the PO gave me back on, runs fine now.
Set the low idle and high limit with this fancy tachometer thingy I got for $1.00. New battery cost more than the tachometer thingy...
I put a set of wheel bearings on it, much better, steering is not sloppy but I could change a few ball joints
The leak seem to stop, But I will prolly end up replacing the seal.
Cut the grass today with it. First time I ever used an Original to cut grass, came out nice.
Old 04-29-2022, 06:45 PM
IHCubCadet147's Avatar
IHCubCadet147 IHCubCadet147 is online now
Nice score!
Old 04-30-2022, 08:20 AM
IHscout79 IHscout79 is offline
Nice unit!
Justin
Old 05-01-2022, 09:46 PM
mrhardware83's Avatar
mrhardware83 mrhardware83 is offline
Default Nice Survivor Tractor
That’s an awesome find. Nice survivors are the best type of find.
My IH Cub Cadet Collection:
(2) Originals
(2) 100’s
(2) 108’s
102
125
71
72
Old 05-01-2022, 09:50 PM
Farmall450's Avatar
Looks to cut nice.
