Old 04-29-2022, 08:40 AM
RoseHillFarmIHCC125 RoseHillFarmIHCC125 is offline
Default Cub 125 rewire
I’m going to rewire my 125 since the engine will be out and at the machine shop. I would like to rewire it and install a new ignition switch. I found a replacement switch on isavetractors, but not the starting solenoid (electromagnetic switch). Is there a part number that you guys would suggest? For wire, I’m considering #10 THHN on the battery and starting circuits and #14 THHN everywhere else. Will these wire sizes be sufficient? My IH or Kohler shop manual doesn’t specify what wire size was original. I found an illustration online, but is there a link or picture on this forum so I know it’s accurate? Thanks in advance, Jay
Old 04-29-2022, 09:31 AM
Billy-O's Avatar
Billy-O Billy-O is offline
Your wiring sizes looks to be very light (too small!!!!) Especially for the battery. I have not done any research, but.....
.....I suggest you get yourself a new wiring harness...Porch Electric makes them.
http://www.porchelectric.com/ihcub.php
Plow blade
#2 Cart
QA36 snowthower
Old 04-29-2022, 09:59 AM
For General Wiring, I use 14 MTW (Machine Tool Wire). Don't like THHN, in that it is, too stiff to work with.
4 Gauge is more in line with Battery Cables.
Old 04-29-2022, 12:16 PM
Thanks for the info, I was planning on taking lots of pictures then laying out the old harness on my workbench. Then, just replace one wire at a time to minimize mistakes. I’m sure my local electrical supply house or big box home improvement store has the MTW you mentioned. I just have easy, free access to THHN. Does the THHN have the same current carrying capabilities as MTW?
Old 04-29-2022, 04:36 PM
MTW may be a little hard to find. THHN will work just fine, it just has the plastic sheath that makes it a bit stiffer.
Old 05-04-2022, 12:53 AM
TheSaturnV's Avatar
I was originally going down the same path for my Cub 147, but by the time I considered the different gauges required, all the end connectors and then thought about years down the road not having the proper color codes, decided to go with a new one.
Completely agree with Billy-O and going with a replacement from Porch Electric. They are fantastic folks to deal with.
Old 05-04-2022, 06:44 AM
I bookmarked their website.
Old 05-06-2022, 01:36 AM
johncub7172's Avatar
Honestly, I have found beautiful unmolested wiring harness for sale that were plug in and play. More power to ya making your own.
Old 05-06-2022, 06:16 AM
Are you referring to Porch Electric? I am probably going to go that route.
Old 05-06-2022, 07:04 AM
Porch Electric......... http://www.porchelectric.com/
