Old 05-14-2022, 08:53 PM
retiredmech retiredmech is offline
Default Mowing deck compatibility
I have a Red IH 682 with a well rusted 50" mowing deck. I have located a yellow MTD Cub 682 with a good 44" deck. I would sure like to know if that deck will work on mine before driving 100 miles to see it. Appreciate any help
Old 05-14-2022, 09:34 PM
First, welcome to OCC.......
The 38C, 44C, and 50C mower decks will fit and work fine, on your 682.
Old 05-14-2022, 10:58 PM
Default Deck for 682
Thank you for your reply. I know a 44C deck will fit my IH682, do you know if the 682 made by MTD used the 44C deck? The tag is unreadable on the deck of the MTD Cub 682. If it was closer I would just go and check it out, it will be worth the trip if I am reasonably sure I can use the deck. Thanks again for your help
Old 05-14-2022, 11:53 PM
Farmall450's Avatar
Yes. CCC & IH made both red and yellow machines (e.g. I have a yellow 782 from CCC, but my dad has a red 782 from IH) for the different dealer streams (red = IH ag, y/w = CC residential/lawn & garden).
Old 05-15-2022, 07:12 PM
Default 682 mowing deck
Thank you for the info. I think I will make the trip and check the condition of the MTD 682. By the looks of the picture it should be worth $500
Old 05-16-2022, 05:34 PM
Farmall450's Avatar
Safe travels. Take some pictures for us
