Old 10-06-2021, 12:58 PM
MarkBednarz MarkBednarz is offline
Default Pulley removal problem
I have a Cub Cadet 106 with a good pulley behind the PTO clutch, that I need to pull, to use on a 104 with a damaged pulley. I've removed the PTO & bearing from the 106 and the 2 set screws from the pulley. I've been soaking with penetrating fluid and it's just rusted on. I've hit it with heat until it's glowing and put water on to help free it up, but still frozen. I've tried a pulley puller, but stopped when it started to flex too much. Any thoughts? Thanks
Old 10-06-2021, 02:48 PM
ironman's Avatar
ironman ironman is online now
Click the sponsor at the top of the page, "Parts by Jeff".
Scroll down until you see "PTO pulley puller".
Old 10-06-2021, 04:22 PM
mortten mortten is offline
Here’s what the book says. Never failed for me but I don’t recall having one really rusted on.
File Type: jpg BD6BAF28-BDF3-4ED0-AE12-A239C970EA25.jpg (15.0 KB, 224 views)
Doug
QA-36A
42" blade
Old 10-06-2021, 08:35 PM
Cubcadet_107's Avatar
I would suggest the puller from Jeff in PA as well, but if you really wanted to make do with what you have there is another option. Simply drill 2 holes through the middle part of the pulley, close to the center, so that you can run bolts through them and use a standard puller.
The holes won't affect the functionality of the pulley as long as you don't drill them too far away from the center and bend the pulley. Of course you also have to be okay with drilling holes in the part, which not everyone is. As a plus it ensures that in the future you'll always have a way to remove it if it gets stuck again.
'70 107 with k301 engine swap
'71 106 with 38" deck
'63 70 "pinkie"
1863 with 54" deck
105 x2 (parts)
Old 10-11-2021, 10:37 AM
Carpetbagger Carpetbagger is offline
Default Pulley Removal
I have successfully used Jeff's puller, after a lot of beating myself and the danged pulley up before deciding to try Jeff's "invention". I would only add my recipe for a solvent to aid in the rust removal. I use an equal parts mixture of acetone and power steering fluid and keep the rusted parts doused and wet while trying to move any part that you want to move or offers to move the tiniest bit. Really works with enough patience. Good luck, Friend. It ain't easy. Carpetbagger
Old 05-18-2022, 01:35 PM
I just got Jeff's tool in the mail a couple of days ago. I tried it last night and wouldn't budge. I soaked it in Kroil several times and tightened it as much as I could with hand tools and left it sit with tension on it overnight. I'm at work now, that pulley is still under tension at home unless it has since decided to budge.
Old 05-18-2022, 03:05 PM
I find that hitting the key breaks the bond, only moving it a 1/16" no further or you will have bigger problems.
Up to 534 and counting...
Old 05-18-2022, 11:13 PM
Ambush Ambush is offline
If you heated it red then dumped water on it, it's most likely never coming off without galling the shaft. That treatment will shrink the hub.
Your best bet is to leave that one on there and get another for the tractor you want to use.
Old 05-19-2022, 12:44 AM
TheSaturnV's Avatar
I've had a lot of success using a prybar behind and applying hits with an air chisel on the end of the shaft. It's a natural motion to hold the pistol and pull a prybar to you. It has worked every time for me. Just switch out the chisel for a point. You'd be amazed what that rapid vibration does to loosen up things and get'em moving.
If you don't have one it's a cheap investment from a Harbor Freight type store.
Tags
kohler 10hp
