Old 05-21-2022, 09:42 PM
jmantooth jmantooth is offline
Default Greetings from Stillwater OK.
Just bought a cub cadet 1000 International. Tractor runs well but I cant engage the PTO from the switch. I know there is a fuse somewhere, can someone clue me in to where the fuse is located? The tractor did not come with any side panels. Can I run the tractor without the side panels installed or will there be issues with engine cooling. thanks in advance for any help with these questions. It appears to be a really neat little tractor and I am excited to own it. Ill try to get some pictures uploaded.
Old 05-22-2022, 06:53 AM
Welcome to OCC........
The Fuse is located on the Dash Tower on the LH side, see image from the Owners Manual on page #5. It is item #3.
Can I run the tractor without the side panels installed ?
Depends......... On how hot of a day. Here in Michigan, I have run my 1450 without side panels, in the cooler part of the year, with out issue(s). IF......all your engine shrouds are in good condition and properly installed, this directs the air flow across the engine, from back to front. This is the major factor in the engine cooling. The side panels help, keep the engine "quieter" (hence the name - "Quietline"), and aesthetic purposes.
Old 05-22-2022, 05:55 PM
thank you. i guess i need to make a quick stop to ebay and see if those panels are available.
