Old 05-29-2022, 03:37 AM
Jfabrication's Avatar
Jfabrication Jfabrication is offline
Default 1450 w/ 60” deck?
Is it possible to adapt a 60” deck system to mount onto my 1450? Would it have enough power to run this if so?
File Type: jpg 6928AF79-518F-47FD-8B8F-971E1D3BC165.jpg (41.7 KB, 114 views)
Old 05-29-2022, 07:47 AM
#1 The wheelbase is too short to hang a monster 60" deck under the Quietlines. The 60" deck is under the super Gt's with approx, 12" longer wheelbase.
#2 you would be under-powered.
An 18 hp would swing a 60" deck if it would fit.
Old 05-29-2022, 08:16 AM
Smile
Short answer...."I don't think so Tim"
Old 05-29-2022, 08:32 AM
CubDieselFan's Avatar
You need a super to mount a 60” Haban.
Old 05-29-2022, 08:45 AM
1711Cub's Avatar
1711Cub 1711Cub is offline
Lightbulb
A 50C is your largest fitting best bet for that machine. However, I think the 14HP will be really working to turn it in heavier grass.
Old 05-29-2022, 08:49 AM
Thanks for those comments, Really needed to wrap my head around just how big the Haban unit is. Ive measured the w/b to be just around 44”. I mow with a Scag 48 primarily, so this 1450 with a 38A feels pretty insignificant even as a backup. Almost 2x as long an ordeal to mow my lot. I suppose a 50” will do just fine if i can find one, until i have a super GT to play with.
Old 05-29-2022, 09:35 AM
Farmall450's Avatar
Farmall450 Farmall450 is online now
50C decks are abundant around me. Keep an eye on marketplace or buy another tractor with one
Old 05-29-2022, 10:46 AM
Bud, the 374's are monsters!
Takes 2 guys to pick one up and move it.
That's a 6' level, flush with the left side laying on it.
And that's without the discharge chute which I do not have.
This is one of two I picked up last week for rehab.
One will go on my 1782 and the other for sale later.
They will be sand blasted, repaired and needed parts replaced, any cracks welded as needed and repainted in Case/IH 935 Iron Guard.
Old 05-29-2022, 10:50 AM
Farmall450's Avatar
I just picked up a 374 yesterday and employed the loader tractor.
2 guys can roll them on the back wheels pretty easily.
Old 05-29-2022, 10:28 PM
Should i be looking for a 50A or C model deck?
CubLife: 125>147>1450
