Remove the 4 torx screws from the seat rails. You will need to slide it all the forward to remove the 2 in the back and then slide it all the way back and remove the 2 in the front.
Remove the forward, reverse, brake pedals on the right and also the differential lock pedal on the left. Remove the left & right rubber floor board inserts. Under there you will find 2-3 bolts that hold the front section to the frame. Remove the gas cap and intake screen under the steering wheel and the fender/floorboard should come off as one piece. I would also replace the spring inside of the valve assembly also. It is part# 732-3059 from Cub Cadet. It is not listed in the parts section from Cub but that is a cyclops part number and the springs are the same.
The two rear torx screws on the seat rails are apparently my problem. I assumed they were there, but my seat does not slide forward far enough for me to see them (which is why I was getting frustrated). Is there a trick to get it to slide forward more? If not, I guess I am going to have to force it and risk breaking it. |
Yes, I had one or two that wouldn't slide either. Take some good penetrating oil like PB Blaster or Kroil and spray the slide rails real good and then sit in the seat and work it back and forth. It will take a little time but it will free up.
Blow the rails out with compressed air to remove any dirt and such before spraying oil.
Thank you for the advice Dark and Oak. I half-expected to be waiting for weeks to get an initial reply, but you all are on it like a rat on a cheeto around here, hehe. I appreciate the help very much, and hope I can contribute something back at some point!
