#21
Well, the drag strip just south of town seems to be going wild every weekend and that's a hell of a lot more expensive a hobby.....er tax write off for some, than these puny tractors.
#22
I wouldn't doubt it. A full fluid change, belts, filters, and a battery are about what a narrow frame is worth anymore...don't even think about tires or a seat.
I can get CC parts at cost + 5%, so probably similar, but didn't want to wait on the dealer nonsense
Why Farm Half When You Can Farmall? 1282 | 44C Deck, 42" Blade, 020" Over K301 * 1711 | 50C Deck, #1 Rototiller w/ Extensions, Sleeve Hitch, CH18S * 1811 | 46 GT Deck, 42" Blade, M18, Sleeve Hitch * 1782 | 60" #375 Deck, Kubota D640 Diesel * 1862 | #450 Snowblower, M18 Magnum * 782 | Y/W KT17 Series II, Sleeve Hitch * 984 | Y/W Onan/Linamar 20HP, Sims Cab, CAT 0 3 PT w/ Rear PTO, 60" #374 Deck * 1914 | 44C Deck, KT17 Series II * 127 * 1650 Twin Stick | 50C Deck, 42QA Snow Thrower, K341 * 1862 |
#23
They are Chinese, not a problem for the tractor that I'm putting these on since I don't run it much but it may matter to some.
#24
What is the OEM?
#25
The currently available MTD issue is made in Worcester, MA USA by Lutco. B1SB6534 64F64PP
582, 682, 782, 782D, 1282, 1050, 1210 x 2, 1711, and 1811 |
#26
They have used those bearings since they started offering 1" spindles and Shep was a pup.
Nothing new here. |
#27
Yup. I was asking what the OEM of the NAPA bearing was.
#28
Probably "The Far East" like 99% of everything else these days.
#29
See attached.
#30
Update on the NAPA wheel bearings above. The packaging says "assembled in China" however when I actually pulled the bearing out, they are Lutco USA bearings. Not sure what that's about but I won't complain.
