Old 06-10-2022, 08:47 PM
EternalArianne EternalArianne is offline
Default Best way to keep a string trimmer cool?
I was over at my grandmother-in-law's place today doing some weed trimming. It's a fairly large lot with lots of trees and fences to trim around. After about an hour of solid work, I shut off the trimmer to change the line. Went to crank it back up and it would idle but shut off when I gave it the throttle. After I let it sit for a good 30 minutes, it worked fine again. So I assume it overheated?
This doesn't seem to be just this particular trimmer, as I had a different one the last time I did this at her property. Except that trimmer overheated after only 30 minutes of runtime.
Is there a good way to keep these things cool? Or is it just the consumer grade equipment isn't meant for long sessions, and I should get a commercial grade unit?
Old 06-11-2022, 10:05 AM
Farmall450's Avatar
Buy a $200 ECHO SRM-225, problems solved.
https://www.farmandfleet.com/product...n-trimmer.html
Old 06-11-2022, 12:28 PM
Echo is the same brand my local repair shop advertises as well. Maybe once my Cub Cadet trimmer dies (which I got for free btw), I might look into a professional grade trimmer.
Old 06-12-2022, 10:16 AM
Farmall450's Avatar
ECHO makes a premium product in Lake Zurich, IL. And, they have a 5 year consumer warranty.
Old 06-12-2022, 11:40 AM
Billy-O's Avatar
Billy-O Billy-O is offline
Sounds like vapor lock. Carburetor gets hot when shut down because there is no fuel and air flow to cool off. Try idling a moment before hitting kill. If that doesn't work, consider richen the mixture a little to run cooler.
Plow blade
#2 Cart
QA36 snowthower
Old 06-12-2022, 05:43 PM
Originally Posted by Billy-O View Post
Sounds like vapor lock. Carburetor gets hot when shut down because there is no fuel and air flow to cool off. Try idling a moment before hitting kill. Of that doesn't work, consider richen the mixture a little to run cooler.
I'll try the idle trick. This trimmer calls for 40:1 ratio, which is what I've been using in it (the premix canned stuff).
Old 06-18-2022, 08:04 PM
Ozcub's Avatar
Ozcub Ozcub is offline
Have a look at how much oil is in a 40 to 1 mix and you expect that to provide good lubrication and cooling , I have been using 25 to 1 mix with no problems also no smoke as the motor is pretty much always running at peak RPM
Some will de-cry my usage but the advice came from some one who makes a living working on small engines , not a hobbyist
Oz
