Old 06-13-2022, 03:32 PM
hogfly hogfly is offline
Default 1863 fuel solenoid
Hello all,
My Dad has a 1863. It started running poorly, everything good to carb. I removed it and cleaned it. Getting ready to put it back on, and try it, but don't know the purpose of the solenoid, when it comes into play, and how to test it thanks.
Kenny
Old 06-13-2022, 05:57 PM
1711Cub's Avatar
1711Cub 1711Cub is offline
Purpose is to prevent fuel from entering the engine when the key is switched off, therefore reducing the chance for backfiring. If you energize the solenoid, fuel must flow through it.
Old 06-18-2022, 11:09 AM
his would not stay running cleaned carb new fuel pump.installed it today same thing did notice you have to keep tuning key on and off till it cranks and if you hold key in crank postion after it starts it runs getting fuel any help appreciated thanks kenny
Old 06-18-2022, 11:15 AM
I just cut the plunger off the solenoid, end of problem.
Old 06-18-2022, 11:46 AM
i did think about doing that but was just wandering if problem with having to keep bumping key may be related when you hit key something clicks after 5 8 times engine will crank thanks kenny
Old 06-18-2022, 02:00 PM
Sounds like you need to add a relay to the starter.
https://www.onlycubcadets.net/forum/...=starter+relay
Old 06-18-2022, 04:13 PM
i think i need to get back up there and check some voltages clean connections switches etc.i have one of these also i checked stuff on mine now i hope i know what to look for thanks sam
