Old 06-19-2022, 11:30 AM
Sergeant's Avatar
Sergeant Sergeant is offline
Originally Posted by lucas View Post
Here is the deal i’m 15 and this is my first big garden tractor, Ii picked this 1872 up a few days ago for $300 and it runs and drives great and fires right up. so my question is would the kit from extreme motor works fit with some minor modifications? I have a small welder and some basic metal working experience.
No need to Modify it! They Bolt right On to the Tractor
Just Invest In this https://www.permatex.com/products/ga...sealant-11-oz/ for the Two Bolt That bolt Into the axle Carrier
I was Just suggesting to Buy CC-03-101M which is 82 Series Cub Cadet - Modified Kit for You Tractor as it Can actually Lift More weight Than a OEM 3 point for You Tractor . The Only thing you give Up is You Can't Put a OEM 2000RPM PTO on it But Most PTO attachments that would fit it Can be Hard to find anyways today except for One Manufacturer Befco the 2000RPM PTO rear attachment are really a dead line anyways. I have other Tractors with the Industry standard 540RPM PTO so In My case I Just want My 2182 Super to Use the Non Power 3point attachments Like a Plow, Cultivator or Disk or a Rear Blade / Box scrape
