Old 07-02-2022, 11:42 PM
bridgewatertek's Avatar
bridgewatertek bridgewatertek is offline
Question Options for #1 tiller belt
What options do I have for the long #1 tiller belt for a 1450 since the correct one is NLA from CC?
Jim Bridgewater, KD0FJO Osage, IA
1976 IH Cub Cadet 1650, 44A rotary mower deck, 42" snow blade, QA42A snow thrower, rear blade, cab
Well, that's out of date. Current count is 2 LT1050's, a 76, 1 2284, 1 2130, 1 2135, 1020, and 10 1250- 1650's, with decks, blades, snow throwers, and a Brinly plow
Old 07-03-2022, 05:51 AM
Charlie has the correct belt for you.
https://ccspecialties.org/belts.html
Old 07-03-2022, 09:13 AM
From Charlie's website
IH - Tiller Belt for Quietline or Wide Frame Tractors 7/16" X 145"PN/ IH-61959-C1 SOLD OUT NLA
IH 61959 C1
Old 07-03-2022, 12:22 PM
mortten mortten is offline
He also has an option kit with replacement pulleys to use a half inch belt but that is temporarily out of stock.
Doug
QA-36A
42" blade
Old 07-03-2022, 04:49 PM
Ooops, sorry, I was thinking it took the 13/32 X 143.8.
Old 07-03-2022, 08:44 PM
I used to have some Ariens 1/2" x 145" belts. Still available from Ariens 07200023 $70.00
You still need the pulleys though...
Up to 534 and counting...
Old 07-04-2022, 07:25 PM
Hairtrigger's Avatar
Hairtrigger Hairtrigger is offline
I put a tiller on my 782. I had no idea what belt.
Put the tractor with gearbox on the trailer and went to my local NAPA
B146 was too short. The next belt they had in stock that seemed reasonable was a B159. It was too long. I ordered a B156 and two days later it fit perfectly
I am not seeing the parts I used all were meant for the 782.
What I am saying is my local NAPA auto store is staffed with gearheads that love little side projects where you do not have instructions to follow
Tags
#1 tiller, 1450
