Old 05-17-2022, 02:39 PM
Farmall450's Avatar
Originally Posted by Steve N Mi View Post
Weeds are pesky but I never thought about sneaking up on em. lol
Haha.
It wasn't that much fun because the cyclops lights aren't very bright and I wired the sprayer in through the tail light (harness was tight going all the way to the battery in the front of the tractor). Which wasn't bad until the switch slid away in the dark so I was turning the lights on/off to control the sprayer
Old 05-18-2022, 10:03 AM
Farmall450's Avatar
Pulled a sleeve hitch off a 1650 parts tractor for my 1811.
Believe I still need to make or buy the straight lift rod and rod mount.
Old 05-19-2022, 03:14 PM
Farmall450's Avatar
Originally Posted by Farmall450 View Post
Played with the 2182. Mowed some, tweaked carb, and sprayed some weeds in the dark.
Mowed (for real) with the 2182 super for the first time. Ran good for an hour. Does seem a little light on power considering it only has the 48 GT deck, but the grass was pretty thick and slightly wet.
Old 05-30-2022, 12:16 PM
Farmall450's Avatar
Cleaned up the 984 and changed the engine oil/filter. Cleaned carb & replaced fuel filter. Runs good!
Old 05-30-2022, 12:25 PM
Farmall450's Avatar
Last night I acquired some 23x10.50-12 Goodyear Terra-Tire (R1) for my y/w 782, and mounted up a turf master on the front to match the RHS.
Hoping to get the carb rebuild and on this week and see if she runs. If so it's getting the sleeve hitch in time to cultivate some headlands before the crops get too big.
Old 07-04-2022, 08:01 PM
Had the 100 running for the first time in a few years. After draining the nasty gas and putting fresh in she fired right up. Then is was time for a long overdue ride. My oldest boy can finally reach the clutch.
Old 07-05-2022, 10:33 AM
Farmall450's Avatar
Looks good for a garage queen
Old 07-05-2022, 09:43 PM
Hairtrigger's Avatar
Hairtrigger Hairtrigger is offline
I moved my dogs to a better neighborhood
About 50” west
File Type: jpg 17F8A959-F88D-467D-9F08-EED884EF7EBF.jpg (36.8 KB, 102 views)
Old 07-10-2022, 01:36 AM
Carverlvr Carverlvr is offline
Finally pulled the trigger on a set ag’s for the rear. Feels much more sure footed now. Maybe add fluid next?
File Type: jpeg 168E5FB5-5320-4FA5-A8EA-C55E2CE8D681.jpeg (33.5 KB, 79 views)
Old 07-10-2022, 09:17 AM
Farmall450's Avatar
First mow with the 984 yesterday. Put the rest of the tin and hood back on last night and am going to finish up mowing today.
