Old 07-31-2022, 02:49 PM
Rmowl's Avatar
Rmowl Rmowl is offline
Default 1863 not starting
Picked up a nice 1863 couple weeks ago. It started and ran fine. Mowed couple times with it, noticed a loss of power then it would pick back up, like a dirty fuel system/carburetor. Replaced spark plugs, air filter, fuel filter, changed oil and filter. Cleaned out carb bowl, blew out the passages. Ran great. Tried just today and engine decreased in power. Limped back to the garage and took carb off, didn’t appear dirty inside. Put back on and now it will just crank and no start. Has 840 hrs. I just assumed it’s a fuel issue, but just guessing, don’t have any experience with the command engines. Not sure where to go from here, thanks for any help
-Rick
IH 782
IH 126
CCC 1863
Old 07-31-2022, 04:51 PM
RLause's Avatar
RLause RLause is offline
Did you re-attach the lead for the fuel solenoid ?
Richard
Old 07-31-2022, 05:24 PM
guyina4x4's Avatar
guyina4x4 guyina4x4 is offline
Pretty sure that has the shut off valve's on the gas tank. They get plugged up with crud.
Might also be the fuel line failing and not allowing sufficient flow?
I think most guys replace the valve's and the grommets and all the fuel line.
JD x475
Old 07-31-2022, 06:45 PM
Rmowl's Avatar
Yes, reattached fuel solenoid wire. I can’t confirm if the fuel lines and shutoff valve are bad or not, but I am getting plenty of fuel. What am not getting now is spark. I cleaned the terminal at the ignition and no change. It would crank and then at another turn of the key do nothing like a bad ground. Also the machine is an 1863 not a 64. Was a one owner with all original receipts, manuals.
-Rick
IH 782
IH 126
CCC 1863
Old 08-01-2022, 03:53 AM
Cannon51's Avatar
Cannon51 Cannon51 is offline
I'm pretty sure the fuel solenoid gets power from one source in run and another in start. Verify that the solenoid is getting power in run and start key positions.
Cannon
Old 08-02-2022, 07:32 PM
rwairforce rwairforce is offline
No spark, you might want to check the coils. I have a Kohler Command 18hp that acted the same and i found intermittent spark using a spark tester between the plug wire and plug. I changed out both coil packs and it fixed it. I contemplated off brand but ended up spending the $100 for OEM Kohler. At least thats what they stated.
Randy
Cubs: 71, 72, 127, 149, 1440, 2186 and 1864
John Deere 110 round fender
John Deere 140 H3
Sears: GTV16
Old 08-04-2022, 06:24 PM
Rmowl's Avatar
I confirmed I’m getting power in start and run. Next I went to coils. Yanked out engine, cleaned it up, waiting on the coils now. The valve grommets disintegrated on both sides of the fuel tank just touching them so replacing both of those and all fuel line. While engine out doing both crank seals. So hopefully once it’s all back together this will solve my issue.
-Rick
IH 782
IH 126
CCC 1863
Old 08-05-2022, 09:32 PM
CubDieselFan's Avatar
Might as well replace the head gaskets while it is out. If they have not been changed you will be going that next.
Old 08-14-2022, 06:14 PM
Rmowl's Avatar
Got it up and running. Runs great and smooth. Replaced both ignition coils, fuel tank grommets, valves and fuel line, crankshaft seals, head gaskets and carburetor. Looks and feels like a new machine
-Rick
IH 782
IH 126
CCC 1863
Old 08-25-2022, 09:36 PM
PeterJ PeterJ is offline
Way to get after it!
From your initial post, I would have bet on the fuel lines. When you said no spark, I would have first tried an ignition switch. They are only about $20. Good to have one on hand. I've seen 4 different GTs have the ignition switch go bad in the past couple of years.
Good to see you got it running like new!
1863 48" deck, 3pt
1864 x 2, 54" deck, power bagger, 48” deck
1811 44" deck 1210 44"deck
IH trip plow
QA42-A, 451 x 2, 551
42" Earthcavator
Driveway Drag
USAF
Shepherd's Chapel
