Old 12-27-2010, 05:56 PM
Sminkey
Guest
Posts: n/a
Default CC-36 driveshaft rubbing??
When I lift the cc36 thrower up to high the driveshaft coming off the gearbox hits the lift bracket and scares the crap out of me every time! It's just barely hitting the lift bracket and was wandering is this normal? If not the only thing I can see to do is to notch the lift bracket where it makes contact or make lift arm stop for the backside of the lift arm. I have only lifted the thrower a few times and caused this but I'm concerned it will do damage. Thanks!!
Old 12-27-2010, 06:00 PM
How about some pictures of this...???
Old 12-27-2010, 06:07 PM
I had one of those and there were springs attached to both sides of the thrower,do you have those?My cc42 has them,I really don't know what they are for.Maybe it will solve your problem if you had them???
Old 12-27-2010, 06:12 PM
Sminkey
Guest
Posts: n/a
OK, I've circled in red where the u-joint hits the lift bracket when I lift it pretty high.
Old 12-27-2010, 06:27 PM
Sminkey
Guest
Posts: n/a
1st pic is in down position, 2nd is up all the way, and it only hits the fat part of the u-joint when it's spinning.
Old 12-27-2010, 06:28 PM
OK....for me there are a couple of things..
(A) Is this CC-36 setup as per the manual..... Manual
(B) Do you have the correct drive belt - Part No: IH-487043-R1
(C) Are you lifting the CC-36 too high because the Lift rod is too short...???
Old 12-27-2010, 06:33 PM
Sminkey
Guest
Posts: n/a
(A) Is this CW-36 setup as per the manual..... Manual
(C) Are you lifting the CW-36 too high because the Lift rod is too short...???
It's a cc36 thrower, I have a cw-36 thrower too but that is not in usable shape right now. I think I have the correct drive belt as the only manual I could find is the cw36, that is the manual I'm going off of. The lift rod is supposed to be original to the thrower, but that makes me wonder now
Old 12-27-2010, 06:38 PM
Sorry for my typo.....I meant CC-36.
My thoughts are....If the belt is too long.....then the GearBox has to set lower on the adjustment slots.
If the lift rod is too short, then it will lift higher than normal.
AND....it maybe a combination of both
Old 12-27-2010, 06:53 PM
Sminkey
Guest
Posts: n/a
Thanks Rolland! I'm gonna have to look at the drive belt and gearbox position to see what is going on, it's not hitting much so a belt a tad to long would do it.
Old 12-27-2010, 07:19 PM
Just a shot in the dark, but if the drive shaft is turned end for end putting the smaller diameter splined shaft above the bracket, would that help? I don't know if that is possible, but just a thought-- I'm thinking the shaft has the same bore on either end but not sure?
