Old 08-22-2022, 10:14 AM
chrismiele chrismiele is offline
Default 42" blade fit 782?
Hello all! I got my 782 repowered with a command 25 and boy is she running strong.
Got a line on a blade, will it fit? Links below and thanks in advance!
Chris.
Old 08-23-2022, 08:48 AM
The pictured dozer blade, will fit any IH Cub Cadet WF Tractor.
Old 08-23-2022, 09:35 AM
Thank you Roland! I am going to pick it up this week.
Once I can obtain a cylinder and dual port hydraulic valve, can this be a power angle blade?
Old 08-23-2022, 09:58 AM
YES, but it won't work well. By the time you angle the blade, the push off from the blade, will be run over by your tires. A 54" blade works so much better. BTDT.
Old 09-02-2022, 02:04 PM
Thanks Roland!! The blade is on and working. I'll work on getting a dual hyrdo valve setup and then report back when it's time to find a 54" and power angle set up. Very much appreciate your help, sir!
Old 09-02-2022, 02:53 PM
42" angle blade works great on my 882, same tractor basically.
Ya just gotta go fast so the snow gets thrown off way to the side
Old 09-02-2022, 03:56 PM
That will do it.
Old 09-02-2022, 05:24 PM
IHCubCadet147's Avatar
That will do it.
Until you hit a rock or edge of a sidewalk and end up on the hood…
Old 09-02-2022, 06:39 PM
BTDT.....
Old 09-02-2022, 08:06 PM
Hey, Ya gotta know where ya go when ya plow snow!!
