Old 08-22-2022, 05:33 PM
Colorado David Colorado David is offline
Default Looking for Snow Plow for 1450 (2050660U)
I'm new to this group but have had the CC 1450 since about 1980. It is in pretty nice condition but I am doing some additional "clean up" work to make it as "like new" as I can. I used it while I lived in Tennessee and left it with a friend when I moved back to Colorado. I have several "implements" for it but am looking for a snow plow to do sidewalks and a little driveway snow removal. Any suggestions as to where to look would be very much appreciated.
Was going to add a pic of my 1450 but couldn't figure out how to add the pic to the post so maybe next time.
David
Old 08-22-2022, 10:13 PM
mortten mortten is offline
You probably can’t post pictures until you have a certain number of posts.
Doug
QA-36A
42" blade
Old 08-25-2022, 01:23 PM
Jumper Jumper is offline
David, what size blade are you looking for?
Old 09-09-2022, 12:46 PM
Default Snow Blade for 1450
Probably looking for a 42" if possible but at this point, I'm open to any options.
Old 09-09-2022, 09:43 PM
Merk Merk is offline
You have mail
Project Uncle Dick
Cub Cadet 70
Old 09-10-2022, 05:53 PM
Farmall450's Avatar
Look me up next time you're in IL
Tags
cub cadet 1450, cub cadet attachments, cub cadet snow plow
