Old 07-11-2022, 05:52 AM
I had some stumps ground down from some trees that were cut last week so I used my 1772 to load up the dirt/chip mixture.
Old 08-02-2022, 01:12 PM
IHCubCadet147's Avatar
I did some driveway maintenance with my 125 over the weekend. I also used my Sears a little bit, but I won’t subject you guys to those pictures.
File Type: jpg 11EB9AA6-3EBC-4CFD-BBBC-A224F977E87C.jpg (39.5 KB, 155 views)
File Type: jpg 299645CA-EE53-4267-BFB9-C1DD0408A468.jpg (39.3 KB, 156 views)
File Type: jpg 171BD541-38B8-4EE6-ABCB-6C160F147B91.jpg (44.0 KB, 153 views)
Old 08-25-2022, 09:42 PM
PeterJ PeterJ is offline
Default 1641
Picked this up:
https://fargo.craigslist.org/grd/d/f...519532633.html
Nice gentleman. I told him he should try another ignition switch. Ends up he is only a few miles from my house so I took one over. That fixed it. He still wanted it gone so now I have too many Cubs, just like before I got this one.
1863 48" deck, 3pt
1864 x 2, 54" deck, power bagger, 48” deck
1811 44" deck 1210 44"deck
IH trip plow
QA42-A, 451 x 2, 551
42" Earthcavator
Driveway Drag
USAF
Shepherd's Chapel
Old 09-10-2022, 09:23 PM
Farmall450's Avatar
Originally Posted by PeterJ View Post
Picked this up:
Upload a picture; the ad is gone.
Old 09-10-2022, 09:32 PM
Farmall450's Avatar
I put the 3 point arms on my 984 today. Took a bit to find the right 5/8 clevis pins (2"); luckily Farm & Fleet had 2x 3" multi-hole ones hiding in the wrong bin. Basically a press fit into the bracket on the tractor.
Old 10-07-2022, 08:43 AM
xcookpac xcookpac is offline
Removed a frozen kingpin/spindle
(AKA Steering Knuckle) from my
Cub Cadet 122. Had a buddy come
over and spent 45 minutes
heating the axle with an oxy-
acetylene torch and beating with
a 5lb sledge onto a brass drift. Long
time since I had such an intense
and difficult heat and beat project.
Old 10-07-2022, 09:00 AM
There is a grease fitting in them for a reason you know!!
Old 10-08-2022, 09:53 AM
I got this CC122 from a fellow that owed me . I used it a couple times but steering was difficult as it was so tight. I was unable to get grease to flow through the existing zerk fittings.
Old 10-08-2022, 09:57 AM
Yesterday, with both king-pins/
spindles (AKA Steering Knuckles) removed,
I removed the existing press-in zerk
fittings. Then I drilled the hole, tapped the holes for 1/4-28, and then installed new threaded zerk fittings.
Old 10-08-2022, 12:32 PM
Way to go!!!
