I doubt you have anywhere near enough weight. 300 lbs. seems to be the magic number for mine.
i am running a 123 with turf tires-8.5'' wide- 4 link chains, i am 150lbs with an extra 120 on the back. 42'' thrower and i really do not have any trouble going through a foot or two of snow. sometimes if i am faced down hill with the thrower off the ground and tryin to back up i spin a little so i am sure a little more weight would solve this problem. of course i would rather have ag tires with two link chains and about 50 to 70lbs more weight on the back.
I run Tru-Power Ags with four 26# weights and 4 link chains on my 1450 with a 42" blade. It does really well. Yesterday, just for giggles, I fired up my 1282 just to let it run for a while. It has no weights or chains but has a 42" blade on it. Anyway, I think my corvette could plow snow better. It was fun pushing it by hand back to the shed while me and the wife laughed. Anyway, It got a good mid-winters warm up.
Moral of the story............WEIGHTS and CHAINS |
My 70 pushes a 54 inch blade with 80lbs a side of wheel weights and about 200 in the weight box. Tru-powers and 4 link chains. BUT turfs and 2 link are better. I just didn't want to change tires around.
well the 2 link are on the way. I am also going to fab up some wheel weight brackets. Does anyone have any pics of a bracket that you put weight lifting plates on?
1969 Cub Cadet 127 Cub Cadet HDS 2155 w/ bagger #2 IH cart 48" deck 42" Front Blade Brinly Sleeve Hitch and Brinly Plow IH wheel weights
Check with the sponsors first, but Aaron at Xtreme Motor Works has exactly what you need. Just a little out of my price range right now.
http://www.xtrememotorworks.com/imag...ptor%20005.JPG
Jim Bridgewater, KD0FJO Osage, IA 1976 IH Cub Cadet 1650, 44A rotary mower deck, 42" snow blade, QA42A snow thrower, rear blade, cab Well, that's out of date. Current count is 2 LT1050's, a 76, 1 2284, 1 2130, 1 2135, 1020, and 10 1250- 1650's, with decks, blades, snow throwers, and a Brinly plow |
Matt,
Are you talking about 150# per wheel + you?
Papaw 1984 CCC 582 w/ creeper, 42" blade, 44C deck, 220# wheel weights, 2 link chains & adjusters, Spring assist lift.
I cleared snow for the first time during the "NY Holiday Blizzard of 2010" last weekend. My 125 seemed to push the 42" blade OK with 2 link chains, a set of IH wheel weights and my 200 or so pounds. My drive is a slight hill, and I tried to keep up with the storm so I only pushed about 6" at a time. In some places I did have to push 12"+ and I still did OK. I was surpised at how well it did. I made plies almost 4' high with it.
Steve, Former multiple 149 owner. Left the tractors back east when we moved to Nevada. One went to South Jersey, the other to Long Island. |
Assuming you're referring to me, yes.
Get the weight on, Jay. If you think spinning tires with chains on a blacktop driveway won't mark up the drive, you have a surprise coming. I've got marks all over my blacktop drive from spinning my chained turfs. Since I didn't have enough weight to keep from spinning, I finally put my 3-bag lawn bagger on the back and filled the bags with snow. That extra weight helped a lot and I finally got the snow plowed off.
Here in VA we got three snows from 15"-26" in under 6 weeks last year. We're not used to that. The first dump plowed off pretty easy, but the next two had no place to go. Had a very hard time getting it off the road because of the berm from the first snow. The extra weight let me push through the old berm and get the snow off the drive.
Tony Stafford, VA 1650, 682... |
