Old 12-28-2010, 08:53 PM
MrGitrdone41's Avatar
i cut the notch out so the stem can go on the outside. See my vid on youtube about it.www.youtube.com/mrgitrdone41/
Old 12-28-2010, 08:55 PM
Stitch's Avatar
Stitch Stitch is offline
I didn't measure, but the bolt's DO line up with the ones on my wheels.
The only thing I can think of is like stated before, the stems were placed differently on the sears tractors.
Says file not found, can you post a pic?
Killin deers and drinkin beers
Old 12-28-2010, 10:32 PM
cub123's Avatar
cub123 cub123 is offline
I have a a few sears suburbans and all of them have the stem on the inside of the rim,so they have no need for a cut out.I also have a set of those weights and they work great! The plastic coated weights for the sears did not get cut outs for the stem until the 80's or so when they moved the stem to the outside.
Old 12-28-2010, 10:43 PM
Stitch's Avatar
What are they made of? Can I drill them out?
Old 12-28-2010, 10:50 PM
cub123's Avatar
I think that they are made of some kind of cement,some of the plastic on mine has been pulled off in places,but it has not seemed to bother it yet,the only thing i can think it would do is erode the cement after some time.As for cutting it,the only thing i can think of is a cement drill bit.
Old 12-28-2010, 10:54 PM
Stitch's Avatar
I'll have to try it. I'm a contractor and I go through masonry bits like nobodys business as it is. I'll try this and post back for anyone interested.
Thanks!
Old 12-28-2010, 11:03 PM
cub123's Avatar
Glad i could help,hope it works!
Old 12-29-2010, 03:49 AM
cdlong's Avatar
cdlong cdlong is offline
Sears tractors have the valve stem on the inside of the wheels.
Papaw
1984 CCC 582 w/ creeper, 42" blade, 44C deck, 220# wheel weights, 2 link chains & adjusters, Spring assist lift.
Old 12-29-2010, 10:54 PM
Stitch's Avatar
I know I can drill the hole, my only question is will this cause the weight to come apart and wind up ruined? Plastic has a tendency to tear over time when you cut through it, and concrete has a tendency to break when you drill it.
Has anyone tried this?
I'd just as soon trade them for different weights then mess them up, but if it's as simple as drilling a couple of holes without much risk of damaging them, then that's what I'll do.
Old 12-30-2010, 10:37 AM
I have a set of JD plastic-coated concrete weights, and they plastic is coming apart, and there's loose concrete under that. For all you know, the concrete has already broken underneath the plastic and you'll just have a mess.
Sell those, and buy ones that actually fit.
