Old 11-04-2022, 12:57 PM
Ian181 Ian181 is offline
Default Whine when p.s. moves
I have a question on an 1862 I just bought. It whines when working the power steering, no leaks, no cavitation, no trans fluid foaming, deck will lower by itself after sitting for a while. Everything is greased, filter changed. I copied and pasted a previous reply, but saw where the valves (? valves) go bad but are not available, so how do you fix this? Substitute valves, live with it???
(From a previous post)
"If the hyd lift goes down its either the valve or cylinder since the pressure has to go to the valve 1st easy way to check is take hoses of cylinder and cap them if it don't go down its the valve we had some issues with Cyclops valves they go bad and from cub they are nla."
Old 11-05-2022, 07:53 AM
Hairtrigger's Avatar
Hairtrigger Hairtrigger is offline
My guess is what you hear is a relief valve partially opening
Old 11-05-2022, 10:30 AM
Whine is normal. If it bothers you get a set of head phones.
Old 11-05-2022, 02:00 PM
CubDieselFan's Avatar
I have a 1864 that would hurt my ears it was so loud. Filter and fluid change fixed it.
https://www.onlycubcadets.net/forum/...ad.php?t=36738
Old 11-05-2022, 08:40 PM
Headphones, lol. Thanks for the replies everyone. I did change the filter, and the fluid looked very fresh, does anyone still think it should be changed?
Old 11-06-2022, 08:14 AM
West Valley G West Valley G is online now
Unless you are having troubles I would let it roll. Every Hydro I own has
some whine to it. Kinda like a whole bunch a people in this world.
Ken
Old 11-06-2022, 09:33 AM
Did you use the correct filter?
Old 11-23-2022, 09:03 PM
Yes, CC 723-3014.
Old 04-21-2023, 09:50 PM
Could air be in the system? Can you bleed the system anywhere?
Old 04-21-2023, 11:23 PM
No way to bleed the system. It may be normal, can you post a video? You would have to post it on YouTube and then post the link here.
