Old 11-22-2022, 02:17 PM
1711Cub's Avatar
1711Cub 1711Cub is offline
Lightbulb
Yes, and Yes.
The Factory Code, and all IH serial numbers were <699,999.
The final IH made 982 was serial number 688712.
The final 782, and also final IH made Cub Cadet was serial number 694248. The CCC era began at serial number 700000 and up.
Old 11-22-2022, 04:50 PM
Farmall450's Avatar
Yes, and Yes.
Minus the introduction of the al rear end.
Old 11-22-2022, 06:21 PM
BKsCC BKsCC is offline
Originally Posted by 1711Cub View Post
Those relief valves are ticking time bombs. They go without warning, and spew Hytran out of them. Not a huge deal. They are easy to find, and easy to replace.
Yeah that's no drama, I used the gentleman on Ebay to swap a set of mine on my 149 and the service was outstanding. Hopefully, that's all it is though, and not something else I couldn't see under all that spewing Hytran.
The hydro being so out of adjustment is annoying though.
Old 11-23-2022, 05:07 AM
That's a bare bones 982 looking at the pic. That will have the Maintenance Minder hour meter, but there is no way of telling how many times it was rolled around. 444 hours is only 20 hours of use a year, but I guess that's possible. It should also have the CI rear with aluminum axle tubes.
The rear cat 0 lift will cost another $400-$600 to add on and another $500-$700 for the rear PTO. Cat 0/2000 RPM implements are hard to find too.
There are several good Onan parts sources out there.
https://onanparts.com/
http://boomersonanparts.com/
Gary's Place in Hope MI
But hey, it's an IH built 982.
Old 11-23-2022, 06:39 AM
That is covered in the Service Manual and can easily be adjusted.
Old 11-23-2022, 06:47 PM
What if I wanted the split brake pedals too? (Why the heck would a garden tractor need dual brakes?)
Old 11-23-2022, 08:21 PM
They're for steering and traction control but I don't really use mine for that. They were optional on the IH built 982's but can be added also.
Old 11-25-2022, 08:50 AM
No I understand what they're technically for, I just can't fathom a situation a garden tractor would need brake steering for. I guess when you have the little one bottom plow on it, but other than that probably nothing else.
Yeah it's bare bones. I'm still gonna get it cause like you said, IH built CC and I'll after-market the 3-pt and PTO once I find an actual implement for it. Should only need the valves replaced and a new paint job. But that's the lie we all tell ourselves getting into a new project.
Old 11-25-2022, 12:05 PM
Gary C Gary C is offline
I guess the steering brakes would work good when pushing snow and you lose traction, I just got my super last year and always forget about that option when pushing snow. Maybe this winter I'll try to remember to check that out. ( last winter the brakes did nothing but kick it into neutral) I adjusted them this past fall, so maybe they'll work a little better this winter.
Old 11-26-2022, 10:59 AM
Not that anyone asked, but here's the pictures I took checking it out. Not too rough, really.
