Old 12-14-2022, 01:15 PM
cubcadet1641 cubcadet1641 is offline
Default Hydraulic Plow
I have a 1994 1641 which only has a hydraulic lift for the snow blade. Has anyone made a conversion to make it a 4 way plow? I'm pretty good mechanically but lack some hydraulic experience.
Old 12-14-2022, 01:36 PM
On the 1641, you can install a 42" or 54" dozer blade:
42 = 190-375
54 = 190-376
Either way, you will need a sub frame 190-377, or 190-316 Sub Frame (on Tractor S/N: 821,101 >)
For Hydraulic Angle, you will need:
* 190-378 Hyd Angle Kit
* 759-3493 Front Outlet Kit
Old 12-14-2022, 03:01 PM
I have the Hyd Angle Kit , but I need to find the front outlet kit. Does that outlet kit come with a 4 way valve for left/ right operations and a control stick too?
Old 12-14-2022, 03:27 PM
A Internet Search comes up with........ https://www.ihccw.com/blades.html?product_id=12423
Old 12-14-2022, 05:47 PM
In 2001
the price was 311.93.
Still a bargain, by the time you find all the used parts that need new parts.
Old 12-14-2022, 09:22 PM
Ambush Ambush is offline
You could get a JD double valve and have two hoses made up to go to the front.
Or mount a cheap two spool valve and take the return oil off the tractors existing valve. Although you only need one more, a two spool only cost a couple bucks more and is the same work to mount. Then you have a spare circuit for something else. Just plug it till you do.
Old 12-15-2022, 11:18 AM
I'll e-mail you the Cyclops service manual. The instructions about how to install the extra valve and front outlets are found on page 7-28 through 7-36
Old 12-17-2022, 08:14 AM
Sam Mac. That would be great. It’s east to find part numbers. Harder to find the parts Thank you
Old 06-14-2024, 07:26 AM
1811woody's Avatar
Sam do you still have this? If so could you possibly email me a copy?
Old 06-14-2024, 07:40 AM
ironman's Avatar
ironman ironman is offline
1811woody, Click this.....
(pages Sam Mac mentions)
https://www.ccpartsnmore.com/uploade...-2082-2182.pdf
