Old 12-29-2010, 10:58 PM
Stitch's Avatar
Stitch Stitch is offline
Default Front blade lift question
I got an IH blade last week. It runs all the way under the tractor to the trailer hitch spot and attaches there, and then hes two arms that are meant to attach to my deck lift arms underneath. The problem is the entire blade assembly appears to be a little long, so the lift arms don't match up quite right. I currently have them hooked together with chains to keep the blade straight and have been using rope to manually raise and lower the blade.........but this ..............sucks.
Is there anything anyone has done to fix this problem aside from cutting the blade assembly and welding it back together 3 inches shorter?
I'll post pics in a few minutes.
Killin deers and drinkin beers
Old 12-29-2010, 11:19 PM
Yamaguy's Avatar
Yamaguy Yamaguy is offline
What model cub are you running it on? I know that that style plow is for later style CC. SOmeone that really knows whats up will chime in soon i'm sure.
Dale
147-Restored___________________882 Diesel
Hydro lift (not installed)___________44" Deck
48" Deck_______________________QA-42a/b Snowthrower
Rear lift ________________________XMW cat-0 rear lift
Model 2 tiller____________________12" cat-0 Brinly plow
Old 12-29-2010, 11:23 PM
Stitch's Avatar
It's on a 100. I may be doomed to lifting it manually, but I sure hope not!
Old 12-30-2010, 06:53 AM
Again........How about a picture of the whole or entire push blade and the model of tractor it is mounted on...!!!!!
Old 12-30-2010, 08:38 AM
Stitch's Avatar
It said it was mounted on a 100 in the last post (above the picture),and to get a good picture of the whole blade, I'd have to take it back off of the tractor, and that ain't happening. I'll see what I can do about getting better pic when I get home later.
Old 12-30-2010, 08:44 AM
Stitch,
That snowblade looks to be off of a cub cadet lawn tractor!
That is the way they hook up on a lawn tractor.
That isn't going to fit on the 100 without some mods.
Old 12-30-2010, 09:03 AM
cubs-n-bxrs's Avatar
Stitch I have never seen a set up like that on a GT cub before. It looks like something that has been taken off a LT style cub. Not saying it won't work but modifications will have to be made.
Old 12-30-2010, 09:19 AM
Stitch's Avatar
I'm actually thinking about trying to put pulleys and cables that hang from the bottom of the tractor, that way the lift will work, only backwards.
Old 12-30-2010, 10:35 AM
That blade is for a late 80s CCC-built, plastic-hood lawn tractor. If you buy the correct blade and subframe for your 100, you will have no problems attaching it.
Old 12-30-2010, 11:45 AM
Stitch's Avatar
I know Matt, but this one was free and just down the road. I THINK I've got it so it'll work. I'll post some pics when I know for sure.
Thanks everyone!
