Old 04-04-2023, 11:48 AM
lpagliaro's Avatar
lpagliaro lpagliaro is offline
Default Cub Cadet 147 Snowthrower
Hello, I am looking for a snow thrower for my Cub Cadet 147. After doing some research, I found that there are a lot of different models that will fit my machine. What is the difference between all of the the snow thrower models? Is my machine under powered for a 42 inch or should I get a 36 inch snow thrower?
Thanks
Logan
Old 04-04-2023, 12:16 PM
You can use, for the 147 these models:
* QA36
* QA42
* QA36A
* QA42A
Old 04-04-2023, 12:25 PM
1711Cub's Avatar
1711Cub 1711Cub is offline
Lightbulb
The QA42/42A was used on previous tractor models with 12HP or less, so your 14HP should have no issues operating the larger unit. These are all single stage units, and depending on who you talk to, were just "ok". The later dual stage units threw snow better and farther, but not entirely sure they can be retrofitted to your model.
Old 04-04-2023, 12:41 PM
Get yourself a 42". A 36' will work but you will be running over more snow with the front wheels during turning maneuvers
I have sent you a PM.
Old 04-04-2023, 12:47 PM
Get yourself a 42". A 36' will work but you will be running over and packing down more snow with the front wheels during turning maneuvers
Old 04-04-2023, 02:01 PM
LAWN BOY's Avatar
LAWN BOY LAWN BOY is offline
Just had to say that my name is also Logan and I also live in Wisconsin.
IH Cub Cadet 70 project, view my thread in the Kohler engines section for progress.
Old 04-04-2023, 03:19 PM
lpagliaro's Avatar
Could you tell me the difference between the QA42/42A?
Old 04-04-2023, 03:53 PM
The QA42 is narrow frame only where as the QA42A & 36A is adjustable so it will fit either narrow frame or wide frame. The 2nd A, standing for adjustable in this case
