Old 04-06-2023, 10:06 PM
1711Cub's Avatar
1711Cub 1711Cub is offline
Thumbs up
The perforated steel grille insert has been cut out, painted and bolted to the grille shell. I know this early design grille was recalled due to debris clogging the grill, but I like the looks of it. I won't be mowing too much with it, and it will stay clean. Also, here is the material I started with. Was just enough to do this grille and the grille on my 1282.
Old 04-08-2023, 09:46 PM
1711Cub's Avatar
Lightbulb
The upper steering column bushing was worn, so I went with a wheel bearing from a much earlier Cub Cadet with the 3/4" front spindles. IH 384881 R94
Old 04-09-2023, 05:04 AM
beancent beancent is offline
Does it seem to steer easier with this bearing in place?
Old 04-09-2023, 03:41 PM
1711Cub's Avatar
Lightbulb
To be honest, it doesn't feel much different in terms of effort, but it is nice and tight without wobble. This will last far longer than the bushing.
Old 04-09-2023, 05:00 PM
Farmall450's Avatar
Nice upgrade.
Old 04-10-2023, 07:38 AM
Now take the steering wheel back off, and install a tie rod boot on the shaft of appropriate size to fit tightly on the shaft, and umbrella the bearing to shed water/debris off it
------unless you promise yerself, yall will not ever get water/dirt in the bearing
Old 04-10-2023, 08:58 AM
1711Cub's Avatar
Cool
Haha
It's fully greased and that foam "seal" was replaced. This one shouldn't get wet often. The tie rod boot is a great idea.
Old 04-19-2023, 09:16 PM
1711Cub's Avatar
Cool
The original mule drive and deck are installed and working. Both new belts installed.
Old 06-06-2023, 07:58 AM
1711Cub's Avatar
Lightbulb
The presumably original throw-out bearing decided to take a dump, so out came the driveshaft/clutch. The clutch disc was practically brand new, so only a new OEM 703-0600 bearing/sleeve, and 732-3017 teaser spring were installed. Now, the clutch is quiet again. The only issue is that the bearing was made in Chyna, but it was physically larger than the one I removed.
