Old 04-20-2023, 09:50 PM
SDBOB SDBOB is offline
Default 1650 Solenoid Went Bad. I have one wire that I forgot.
Solenoid went bad. So I took old one off then got CC replacement. When I went to put wires back. I have a tan wire I'm not sure where it goes. The eyelet will not fit a 5/16 bolt.Should have taking a picture. I have factory wiring schematic. The tan wire isnt shown near solenoid. Tractor runs fine. Mower etc. I checked wire for voltage in run position nothing.Can someone help me? I've learned to take a picture and write it down. Duh. Thanks.
Old 04-21-2023, 07:07 AM
ironman's Avatar
ironman ironman is offline
Does your PTO work??
Old 04-21-2023, 07:21 AM
IF.........Your wiring is original and un-molested, there are two small gauge wires that connect to the Starter Solenoid.
* An Orange Wire that comes from the Brake Pedal Switch, which supplies the power for engagement to the small stud.
* An Red/White Wire that goes to Amp Gauge which is connected to the Large Terminal going to Battery + cable.
Old 04-21-2023, 09:03 AM
That's the same schematic I have. Yes, PTO works fine. Only thing I noticed was the amp gauge was reading Discharged with brand new battery. Ran fine cutting grass for 2 hours. It restarted fine. The only terminal it could fit would be the small solenoid terminal. Wires eyelet is shiny. I'm kicking myself for not labeling when I took it off. I tried to visually trace it but wires are bundled. Next would be using meter. Maybe some was in there before me, as tractor was not taken care of, just used when I got it.
Thanks guys.
Old 04-21-2023, 10:24 AM
ironman's Avatar
Check that the small red/white wire from the amp meter is going to the same heavy lug as the battery cable and not the one from the starter.
Old 04-21-2023, 09:23 PM
Ah ok. When I took it apart those 2 wires were together like they were connected so I didn't separate them.i will ck probably Monday. Thank you.
