Old 04-25-2023, 11:14 AM
Mr Bob's Avatar
Mr Bob Mr Bob is offline
Default Drive shaft to Pump
The shaft from the pump is showing a lengthy spline. Is this normal or is something amiss. Picture attached. Thanks for looking and have a great day
Bob
Old 04-26-2023, 04:15 PM
I would check and see if the retaining spirol pin has failed if the tractor is a pre cyclops tractor or if it's a cyclops has the retaining bolt backed out.
Old 04-28-2023, 09:10 PM
Mr Bob's Avatar
Default Driveshaft
Sam, the tractor is a cyclops 1862. It looked like it is held by 4 bolts at front of drive shaft. I am going by memory of a couple days ago so it may be incorrect.
I will have to go down in the garage tomorrow and have another look. Thank you for responding and have a great day.
Bob
Old 04-29-2023, 06:52 AM
You will need to remove the 4 allen head bolts that hold the CV joint together #7 and then you can get to the bolt that holds the pump adapter on the pump input shaft #11 circled in red
Old 04-29-2023, 08:45 PM
Mr Bob's Avatar
Default driveshaft
Sam, thanks for posting the diagram. I will have to study this as my mind is not working too well recently. Have a great day.
Bob
