Old 05-01-2023, 06:20 AM
I don't think your short is in the carb solenoid because I don't think the tractor would run if it is shorted or failed. You need to use a multi-meter like Ironman posted. Set the meter to Ohms(resistance) and attach one lead to the black wire leaving the fuse holder and the other to ground. Try that and report back.
Old 05-01-2023, 12:14 PM
ironman's Avatar
ironman ironman is offline
Originally Posted by malibulvr View Post
I tested the ignition switch and thought it was bad but the new switch is doing the same thing.
A question that should have been asked from the get-go, and that is...
What is the part number of the new ignition switch that you installed??
Just asking because many ignition switches look alike on the outside but make different connections inside when you turn the key.
Don't want to chase the wrong tail here.
Second question....
What is the number on the new diode you installed?? (something like 1Nxxx)
Old 05-01-2023, 07:01 PM
malibulvr malibulvr is offline
Second question....
So the ignition switch HDK-152 and diode is 1N5400. I can get the tractor to run now but only if the red wire to the voltage regulator is not attached. Once I plug that wire in, the fuse blows.
Old 05-01-2023, 07:35 PM
925-3163 is the correct switch, not sure what a hdk 152, is it a cross to the cub cadet one?.
Old 05-01-2023, 08:29 PM
HD Switch Ignition Key Switch for Cub Cadet MTD White Outdoor 925-3163 725-3163 925-3163A 725-3163A 725-3163P - Dual Dust Protection System - w/ 2 Keys & Free Carabiner https://a.co/d/gH1cFUd
Old 05-01-2023, 10:04 PM
Your problem started with the deck lift, the main wire harness runs along the frame on the left side and runs up through the steering column area where there is a junction connection. Check that area for a wire that has rubbed up against the frame or the steering wheel shaft.
Old 05-02-2023, 06:56 AM
That was the first thing I did, could not find any rubs or pinches.
Old 05-02-2023, 05:24 PM
Radioguy41's Avatar
Radioguy41 Radioguy41 is offline
I'm not entirely familiar with the specific wiring on this CC but to me red means hot and black means ground so when I see a red wire plugged into a black wire it makes me wonder if that's the way it's supposed to be?
2005 CC GT2544
1980 IH CC 782
1957 Cub Lo-Boy
1993 Craftsman LT4000
Old 05-02-2023, 07:28 PM
That wire goes to the carburetor solenoid, black sleeving maybe..
Old 05-02-2023, 07:40 PM
It's entirely possible that you have a bad voltage regulator. I don't like the B&S regulators, I replace them with Kohler VR's. This is the Kohler part # that I use 41-403-10-S regulator.
