Old 04-30-2023, 03:27 PM
Tony h's Avatar
Tony h Tony h is offline
Originally Posted by Ambush View Post
Just went to use my 149 the other day to do some food plot prep. I had to drive it about a 1/4 mile on a laneway and right away noticed the one wheel bearing was shot and I need it now as there was (should have been) a break in the rain predicted. I found some on Amazon with a two day delivery and it looked like a pack of four for $18. But reading the comments, one guy said, "... beware, this is for only one bearing...".
So being as they are probably cheap, offshore bearings, I order four.
Yup, you guessed it, I got four packs of four!
Anyway, I popped the inner seal off and re-greased two and installed them. Probably fine for tilling, but no way will they stand up to loader work. The bearing bores on the rims are about shot too, so I may machine a tube for some huskier bearings and weld those into the rims.
Improving those Shoulder bearings sounds like a sound idea. I don't even like them on my wheel barrows
If I can't fix it , it must not be broken
Old 05-04-2023, 12:07 PM
Ambush Ambush is offline
Well, after a year of loader work and general duty the $4.50 bearings are holding up fine. They're so cheap and I got so many that I'm using them for other stuff too. I built a hilling attachment for the homemade tool bar and used four of the bearings for the dic hubs.
Old 05-04-2023, 12:12 PM
The bearings in the hiller hubs
