Old 05-19-2023, 11:25 AM
Nozzlehead Nozzlehead is offline
First, welcome to OCC........
You can simply use a straight bar, using the dimensions in the image. I have been using the straight bar on 782 for 20+ yrs.
Does the true 3 point hitch plate take the same length as the sleeve hitch set up?
Old 05-19-2023, 12:55 PM
Sleeve hitch adaptor type lift uses lift bar #703-0408 and is for 782's w/ser #'s 719999 and lower w/IH cast iron differential housing.
Cat '0' type 3 point is used w/ser #'s 720000 and up used lift bar #703-0811 and the aluminum differential housing.
Two different animals.
Old 05-19-2023, 04:50 PM
Sergeant's Avatar
Sergeant Sergeant is offline
Originally Posted by Farmall450 View Post
He said he wasn't looking for the sleeve hitch one (I know the purists like to call the sleeve hitch/Brinly adapted setup a 3 point, but that was really a misnomer on IH's part by today's standards).
That's what I thought, but I was confused by Roland giving him the Part Number for the straight IH 3 Point Bar. I gave him the Part Number for the True MTD Cat 0 3 point Hitch Lift Bar.
I bet Aaron from Xtreme would give him the dimensions for the bar if He wants to make it himself. Aaron's bar is based On the OEM Cat 0 Lift Bar, not the IH 3 Point Lift Bar. If anybody has a standard Garden tractor with the MTD Made Cat 0, they could give him the dimensions as well for the Hydraulic Lift Models, used Bar 703-0811.
Old 05-22-2023, 05:46 PM
Farmall450's Avatar
Originally Posted by Sergeant View Post
That's what I Thought, But I was confused By Roland Giving him the Part Number for the straight IH 3 Point Bar, I gave him the Part Number for the True MTD Cat 0 3 point Hitch Lift Bar.
I bet Aaron from Xtreme would Give Him the dimensions for the Bar if He wants to Make it himself because Aaron's Bar is based On the OEM Cat 0 Lift Bar Not the IH 3 Point Lift Bar basically if anybody has a standard Garden tractor with the MTD Made Cat 0 they could give him the dimensions as well for the Hydraulic Lift Models used Bar 703-0811
It's public info when the repros are just the IH/CCC design.
Old 05-23-2023, 08:38 AM
Sergeant's Avatar
I know it's public info, but Aaron already has the correct dimensions
Old 05-23-2023, 03:17 PM
Farmall450's Avatar
Yup, I was agreeing with you.
